coil rail mystery part - JeepForum.com
post #1 of 4 Old 03-10-2006, 07:49 PM Thread Starter
bubbalooey
Pulled the coil rail on my 01 cherokee 4.0L and a 1" polished metal sleeve or bushing fell off it. It's the right diameter to fit into spark plug boot. Anyone have any idea where it goes and/or what it does?
bubbalooey is offline
post #2 of 4 Old 03-10-2006, 09:20 PM
winks00XJ
winks00XJ's Avatar
More than likely it is a spacer for the rail so when you tighten it up you dont crush the plastic. I have had the coil rail off of mine a few times but never had one of those things come off. Hope this helps.
winks00XJ is offline
post #3 of 4 Old 03-10-2006, 09:36 PM
rob92xj
1992 XJ Cherokee
Sounds like the sleeve for the coil or for the heater hose holder if you had moved it.
rob92xj is offline
post #4 of 4 Old 03-11-2006, 08:29 AM Thread Starter
bubbalooey
Got to believe you've solved it. I did move the hoses and I'll bet it fell off. Thanks a bunch!
No way to test or check coil rail, correct? BlkBird XJ Cherokee Technical Forum 8 03-08-2009 10:05 AM
How do I test the coil rail on a 2001 to see if it's good/ bad akxj01 XJ Cherokee Technical Forum 9 01-15-2009 07:17 PM
Replacing coil rail on 2000+ CScheip XJ Cherokee Technical Forum 8 03-03-2007 10:22 PM
High performance coil rail? numnuts XJ Cherokee Technical Forum 3 06-26-2005 04:02 PM
2000 sport coil rail thingy jimbir XJ Cherokee Technical Forum 2 01-05-2004 10:43 PM
