coil pack install ? - JeepForum.com
post #1 of 5 Old 10-28-2008, 07:20 PM Thread Starter
jshaab2
coil pack install ?
hey guys if you noticed my other threads are about rough idle heat soak. misfire in cylinder #3 and i changed spark plugs and now i hear ticking noise. and idle is rough and i attempted everything. so i made up a few options. buy a new coil pack and just wing it or send it to jeep for a couple hundred?
now option one. if i buy the coil pack how are is it to install on a 2001 4.0 Cherokee second i have the 2 hoses and accelerator cable in the way. so any advice on install and removal. how bout the wire harness is that east to disconnect ?
01 xj sport . SS headlights sound system . dakota AT's 235/75 sound system and front and rear recovery, CB . AUX lighting EXIT 105 NJ
jshaab2 is offline
post #2 of 5 Old 10-28-2008, 07:55 PM
red96jeep
you can get ignition kits that come with new wires, cap, and rotor for less then 100 and i think even one company sells it with a coil pack. i did it without the coil pack and it noticably helped my idle quite down and run cmoother all across
1996 jeep cherokee se 2 door
5 inch lift
rear ended= totaled
Rocky Mountain Edition Club member #4
project vehicle
new 2002 jetta 1.8t DD
red96jeep is offline
post #3 of 5 Old 10-28-2008, 08:35 PM
filluptrk
Which plugs did you use? Phil
filluptrk is offline
post #4 of 5 Old 10-28-2008, 08:39 PM
Mr_Random
1986 XJ Cherokee
He's talking about the distributorless ignition system, no distributor (obviously, haha). Three coil packs and a cam sensor, yep...
Sorry I can't actually help! Just trying to clarify for someone else to help...
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline
post #5 of 5 Old 10-29-2008, 03:10 PM Thread Starter
jshaab2
thanks guys i was fed up so i just sent it over to jeep
jshaab2 is offline
help swaping a coil pack xjjake99 XJ Cherokee Technical Forum 2 08-19-2009 12:37 PM
Where Can I Get A Coil Pack From? OLDoRedoWolf XJ/MJ Cherokee Non-Technical Forum 6 02-15-2009 01:50 PM
coil pack install ? jshaab2 XJ Cherokee Technical Forum 3 10-29-2008 07:52 AM
Bum coil pack?? Jenniegirl XJ Cherokee Technical Forum 6 03-24-2005 08:29 AM
Coil Pack Question MDP_JeepN XJ Cherokee Technical Forum 1 09-28-2004 06:39 AM
