Coil Over Rear Suspension Conversion - JeepForum.com
post #1 of 10 Old 04-20-2005, 07:30 PM Thread Starter
ATX XJ
Any one here know how to do a coil over conversion in the rear? I will be working full time in an auto shop now and will have access to everything i wud think that i would need and im really interested in doing it. info plse! any writeups out there?
Cherokee 4.0 4x4 231/AW4 30/8.25 BLACK
TEXAS LONGHORNS
ATX XJ is offline
post #2 of 10 Old 04-20-2005, 07:35 PM
XJ-NoDough
XJ-NoDough's Avatar
I don't know of any write-ups but here is a complete kit. http://www.rockkrawler.com/index.php click on jeep products then XJ of course, then XJ suspension systems, then look at the bottom two. This might help you get an idea.
My DD
'89 XJ Limited
204,XXX miles
Leather, Loaded
4L Selec-trac
Automatic
3"-4.5"ish Homebrew lift
16x8 MB Motoring Rockers
265/75R16(31ish"X10.4") Goodyear Wrangler M/TRs
Trimmed w/ Bushwackers
Stock 3:55 gears
sans big audio
Homebrew intake w/cone filter
"Some people are like a slinky... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs." :my dad
XJ-NoDough is offline
post #3 of 10 Old 04-20-2005, 07:37 PM
gwarusee
I really wouldnt go with that conversion unless you are really adement about it. There are so many negatives that come along with it just for that little bit of extra flex. Replacing the stock style set up (in this case leaf springs) with a totally new system can also void insurance if you are to mess your car up in an accident, or soemone else's. They will use that simple conversion to justify your jeep as incompetent and make sure you recieve no benefits what so ever. My friend did a leaf spring conversion in the front and ended up wrecking . During the wreck the front right leaf tore out and this was used against him.
Sorry for being so negative about it, there are quite a few people who do this conversion and there are even a few kits that you can buy, I would just be really carefully when you decide what to do.
gwarusee is offline
post #4 of 10 Old 04-20-2005, 07:42 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Basically hit Pirate4x4 and search for "tri link". There shoulbe be a couple of write up on home brewed stuff there. From what I gather, the tri link is preferred over the 4 link rear. Basically take the front setup and reverse it to the back. You'll need brackets for the control arms, trac bar body mount and axle mount, and spring perches. That or a stock TJ setup.
Is your old man okay with a coil over conversion? That's a lot of work for a vehicle that might not be lifted all that much.
SERIOUSLY consider a Explorer 8.8 with that rear setup. The fabbing required to get teh rear axle to work with coils would be the same on a stock axle, so you might as well upgrade.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #5 of 10 Old 04-20-2005, 07:57 PM Thread Starter
ATX XJ
i know its a big project but i figured that with the resources ill have at hand i might as well look into it some. is the 8.8 already coil ready? what are some disadvantages of the rear coils? from what ive heard they r pretty advantageous...better flex...seems easier to lift/cheaper.
TEXAS LONGHORNS
ATX XJ is offline
post #6 of 10 Old 04-20-2005, 08:13 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
No, the 8.8 is not a coil over setup till the 99 model. I would assume the perch widths are different from the XJ due to the fact the axle themselves are slightly narrower (about 1-2"). I beleive the TJ D44 would have different mounts as well.
The "best" way to fab a coil ready rear would be the M.O.R.E. 8.8 conversion kit for the TJ and then mount the perches where you'll need them on the XJ.
Depending on how stable the rear mounts are, the trac bar is a MUST. I believe the Tri-link setup offers the most stability.
Personally I think that a coil over is a HUGE first step. I would suggest doing a explorer axle conversion on the leaf springs first, then building up a set of Rock rails, front and rear bumpers, even an interior roll cage before tackling the coil over.
Hell, even a front long arm would be a good starting point. Lots of info out there about doing a homemade setup for that, but not as much for a rear coil over.
93 Sport
Specs in Profile.
balloo93 is offline
post #7 of 10 Old 04-20-2005, 08:18 PM Thread Starter
ATX XJ
awsome...thx for all the info balloo. looks like custom rockrails and bumpers and maybe even a cage and axles are in my future before i tackle something like the coil-over rear. balloo feel free to visit the shop this summer where ill be workin. its don's auto shop down on south 1st st. i think i start may 25th or so
TEXAS LONGHORNS
ATX XJ is offline
post #8 of 10 Old 04-20-2005, 08:29 PM
wipedawg
wipedawg's Avatar
if you are going to fab up a bunch of stuff... might as well make the rear a ford 9 or a d60,,,, geter dun right the first time.
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline
post #9 of 10 Old 04-20-2005, 08:35 PM
JIMBOJAMES
you could go and cut all the mounts off a ZJ at a junk yard and weld them to your XJ. Then go from there.
96 Cheorkee Sport - 6.5" Lift, with 33X12.50 BFG MT's, big bumpers
JIMBOJAMES is offline
post #10 of 10 Old 04-20-2005, 10:51 PM
xjj33p3r
xjj33p3r's Avatar
www.claytonoffroad.com
They JUST came out with a rear coil kit. Buy that, weld it on, and you're done. Lifetime warantee on parts. Pricey but worth it.
xjj33p3r is offline
Coil sprung conversion for the rear? ProMod1385 XJ/MJ Cherokee Non-Technical Forum 10 07-15-2008 08:47 AM
Rear coil conversion?... Bryson XJ Cherokee Technical Forum 11 12-30-2007 01:31 PM
whos done a rear coil over conversion on their XJ? laurxj XJ Cherokee Technical Forum 4 10-24-2007 12:06 PM
ZJ/WJ Rear Coil Spring Conversion StokedXJ11 XJ Cherokee Technical Forum 4 01-07-2007 01:57 PM
Rear coil conversion WhiteKee XJ Cherokee Technical Forum 7 11-23-2005 05:47 PM
