Codes P0443, P0545, P0700, P0705, P1491, P1694 -
post #1 of 1 Old 07-24-2013, 02:53 PM Thread Starter
Hi, I'm new to the forum, but I've been searching it via Google for a couple of weeks, since buying a 1998 Cherokee Classic.
My Jeep had all of the above codes in the computer when I bought it, the air conditioning, backup lights, cooling fans and overdrive didn't work, and it had a rough idle/hesitation on startup. In searching the forum, I saw a couple of people recommend replacing the Number 10 fuse in the kick-panel fuse box for different problems. Trouble is, my owners manual said the Number 10 fuse slot is unused and the slot was empty.
After a quick Google Search for a diagram of the fuse panel, I found a site that said it is used and many of the relays it powers were ones associated with the check engine codes that were set.
Long story short, I put a 15-amp fuse in the number 10 slot and it fixed my air conditioner clutch problem, my cooling fans, my overdrive, my fuel evap system problem and my backup lights.
Thanks for the help! It saved me a bundle.
4xsearcher is offline
In order to be able to post messages on the forums, you must first register.
