Code P0138 high voltage code, Bank 1 sensor 2? - JeepForum.com
post #1 of 22 Old 05-03-2009, 09:05 PM Thread Starter
crmaverick89
2015 JK Wrangler
My check engine light has been on with a P0138 High voltage code, bank 1 sensor 2. I replace the 02 sensor near the manifold (before the cat) as told to with a Bosch, but the light is still one, even after i reset the code it came back on. I checked my ground to the engine block which is good, and my 15A fuses look good to. Any other ideas as to why it getting high voltage, is the rear 02 sensor causing this and need to be re-placed? Anyone else with this problem figure it out?
thanks
crmaverick89 is offline
post #2 of 22 Old 05-03-2009, 09:40 PM
sbrunner
I had that code also. I replaced the rear o2 sensor and it went away.
sbrunner is offline
post #3 of 22 Old 05-04-2009, 06:03 AM
x99j
you got the wrong sensor. sensor 2 is the one after the cat so you might want to do more research. mike
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #4 of 22 Old 05-04-2009, 08:27 AM
Ed Rico
1997 XJ Cherokee
The rear O2 sensor *is* the one after the cat as pointed out by X99J above, so replacing the front won't resolve this code.
The P0138 high voltage code indicates an open in the rear sensor heater circuit. It may be a bad internal heater within the rear O2 sensor, you could check the heater wires (dark green/white and black) for continuity. If the sensor heater checks out OK, you're stuck with checking the rest of the circuit from the PDC to the ground stud next to the dipstick to find the open.
-Ed Rico
Last edited by Ed Rico; 05-04-2009 at 08:37 AM. Reason: Responded too quickly, sorry for any confusion.
Ed Rico is offline
post #5 of 22 Old 05-04-2009, 10:14 AM Thread Starter
crmaverick89
2015 JK Wrangler
By checking the circuit and wires do you mean checking for melted insulation or using a tester? If the wiring checks out all good ill replace the rear 02 sensor
thanks
post #6 of 22 Old 05-04-2009, 01:12 PM
Ed Rico
1997 XJ Cherokee
What I meant was using a meter to check the circuit for continuity. But to your point, checking for melted insulation would be helpful and could yield some useful clues to finding the problem. Just be careful when checking the sensor itself to probe the 2 heater wires (colors listed above) and NOT the 2 sensor output wires. You don't want to risk damaging the O2 sensor by applying a voltage across the sensor output, and besides it won't help you solve the problem.
-Ed Rico
Ed Rico is offline
post #7 of 22 Old 05-04-2009, 04:40 PM
Bnugget
After CAT sensor
What does the 2nd sensor do? Adjust fuel mixture, or is it for emmissions only? I'm getting the P0138 now, it seems to be a fairly common code.
Thanks in advance,
Bnugget
Bnugget is offline
post #8 of 22 Old 05-06-2009, 04:52 AM
Ed Rico
1997 XJ Cherokee
Rear O2 sensor on OBD-II monitors oxygen content of exhaust stream downstream of the cat. This information is used to compare to the upstream (pre-cat) O2 value in order to determine if the cat is functioning normally. The rear sensor has no direct effect on air/fuel mixture, but can have an important indirect effect since the internal resistance heaters for both sensors are wired in parallel. If a problem with the rear sensor heater knocks out the fuse in the PDC, the front sensor heater is disabled as well which can negatively affect driveability.
-Ed Rico
Ed Rico is offline
post #9 of 22 Old 05-06-2009, 11:31 AM
kadetklapp
1997 XJ Cherokee
I've got this code as well. Weird.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #10 of 22 Old 05-06-2009, 09:29 PM Thread Starter
crmaverick89
2015 JK Wrangler
ya I still haven't figured it out, im gonna try replacing the rear 02 sensor i guess
post #11 of 22 Old 07-02-2009, 05:24 PM
bfolla06
are the front and rear sensors the same?
bfolla06 is offline
post #12 of 22 Old 07-02-2009, 07:17 PM
Jay-P
Nope, front adjusts air/fuel ratio, rear just senses oxygen in the exhaust. Read Ed Ricos post above.
1992 YJ + 2012 JKUR
Jay-P is offline
post #13 of 22 Old 07-03-2009, 09:00 AM
Ed Rico
1997 XJ Cherokee
Front and rear O2 sensors have physically different connectors, otherwise they are the same. That's why the replacement sensors that require splicing your old connector are the same for front or rear applications.
-Ed Rico
Ed Rico is offline
post #14 of 22 Old 08-23-2009, 05:38 AM
meldredge1
Fuse location?
My downstream O2 sensor wires (behind the cat) fell on the driveshaft wearing through them. I am having the same hot engine misfires/sputtering problem as described in these posts and the same code. After the sputtering began I spliced the wires together but the problem continues. After reading the Upstream and Downstream O2s run on a parallel circuit I thought I would check the fuse. Do you know where it is located? I thought that possibly the Downstream O2 short may have also shorted the other Upstream o2 sensor? What do you think?
Mike
meldredge1 is offline
post #15 of 22 Old 08-23-2009, 07:27 AM
Ed Rico
1997 XJ Cherokee
O2 sensor heater circuit fuse is located in the Power Distributon Center under the hood. If you damaged the wiring to the rear sensor, it likely shorted the heater circuit, effectively knocking out the heater to both sensors.
-Ed Rico
Ed Rico is offline
Code P0138 - What do I need to fix an O2 sensor Dannyboy18 XJ Cherokee Technical Forum 3 03-24-2011 11:37 AM
Check Engine Light - 02 sensor voltage too high bank 1 sensor 2 billbarr100 XJ Cherokee Technical Forum 15 05-19-2010 03:04 PM
Trouble with oxygen sensor code p0138 123mylesl XJ Cherokee Technical Forum 1 09-15-2008 10:37 PM
code 463: Fuel Level Sensor Circuit High Input??? nickwc XJ Cherokee Technical Forum 1 09-16-2004 06:10 PM
P0138 Oxygen sensor high voltage, bank 1 sensor 2 Back2Basics XJ Cherokee Technical Forum 3 08-03-2004 11:33 AM
