cluster voltage gauge showing wrong voltage. - JeepForum.com
post #1 of 8 Old 03-03-2005, 07:57 PM Thread Starter
BackDraft
I've had the entire charging system checked, everything is above 13.5 volts...but the guage in the dash varies...daily actually.
I read in an odd post somewhere, about cutting a trace on the back of the cluster and wiring the guage directly to the alternator?
anybody remember this?
96 Cherokee Sport
4.0L I6 - HO, AW4 Auto Tranny / NP231 Transfer Case
Painted black stock steelies with 31x10.50's
BackDraft is offline
post #2 of 8 Old 03-03-2005, 10:01 PM
crashod
I have the link at work. If someone doesn't post it before tomorrow I will.
88 XJ Stock 201,XXX Miles
Runs Great $750.00 From Second owner.
Everything but the Cruise control Works.
crashod is offline
post #3 of 8 Old 03-03-2005, 11:05 PM
canadianmudinus
i was driving the other day from SC to NH... during that snow storm.. around NJ i got alot of slat spraying all over me and i think it messed up my Alternator... and my gas guage... my alternator when under load would show the volts running down to almost 9 and everything would dim.. i hit it with a can of electronics cleaner and has since stoped and appears to run fine.. but my gas guage is still messed... will not read right... says 1/2 tank all the time unless you fill it up the it says full and SLOWLY trickles back to 1/2
i think the salt water on the road shorted something out...
canadianmudinus is offline
post #4 of 8 Old 03-04-2005, 09:13 AM
crashod
This site was linked here before and it might help you. The guy has some pretty good articles about electrical stuff.
http://www.olypen.com/craigh/electrical.htm
crashod is offline
post #5 of 8 Old 03-04-2005, 12:06 PM Thread Starter
BackDraft
busted link?
96 Cherokee Sport
post #6 of 8 Old 03-04-2005, 03:58 PM
crashod
Works when I click on it... Hum, I don't know.
crashod is offline
post #7 of 8 Old 03-04-2005, 05:31 PM Thread Starter
BackDraft
that's weird, mustve been an internet-burp ....working fine now! Thanks!
that site was certianly helpful, but not quite what I was looking for, any other vounteers of information?
96 Cherokee Sport
post #8 of 8 Old 03-12-2005, 01:44 PM
jeep89
If the voltage is good, at 13-14volts at the battery, but not the gauge, and your lights are real dim, etc. check your ground strap. Look along your firewall until you see a braided cord. It should be in the middle attached to the firewall and back of the block.
jeep89 is offline
voltage gauge bad? beepbeepjeep09 XJ Cherokee Technical Forum 3 02-07-2010 09:52 AM
Voltage gauge reading 19? 99WhiteXJ XJ Cherokee Technical Forum 4 08-10-2009 02:56 PM
Renix voltage gauge fix!!! Aquit45 XJ Cherokee Technical Forum 9 07-24-2009 10:06 AM
Voltage gauge? tarheel4x4 XJ Cherokee Technical Forum 4 06-04-2006 02:58 PM
Voltage gauge surge to infinity Maco98XJ XJ Cherokee Technical Forum 5 08-30-2005 05:25 PM
