Clunking from transfer case. - JeepForum.com
post #1 of 2 Old 02-27-2013, 08:47 PM Thread Starter
aldersonfilm
With the front wheels jacked off the ground, if I spin the tires, there is a clunking coming from around where the front shaft meets the transfer case. It may be coming from the case itself, but the shaft itself has some spin play to it. I JUST replaced the u-joint on the driver side axle shaft. I guess another u-joint is bad??? Any other possibilities?
aldersonfilm is offline
post #2 of 2 Old 02-28-2013, 07:35 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
A slight clunk is normal.
CJ7-Tim is offline
drive shaft , tranfer case , u joint , u joint replacement , yoke
