"Clunk" When going from Reverse to Drive - JeepForum.com
post #1 of 7 Old 06-05-2013, 07:40 PM Thread Starter
HawksWin
This only happens when going from reverse to drive. When you do it, its a big clunk. Now if i go reverse to neutral, let it get out of gear then drive, its not as bad. Should i be concerned about my rear diff gears? I had a friend shift while i laid underneath and the rear end jumps. I noticed the front U joint on the rear driveshaft is a little loose when in neutral, but nothing that would cause this big of a clunk. Any suggestions?
Thanks,
Trevor
Also, Its a 2000 Cherokee Sport 4.0 I6
HawksWin is offline
post #2 of 7 Old 06-05-2013, 08:03 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If the u-joints are worn or loose, replace them. Some clunking when shifting between P, D, or R is normal. You can try pausing in NEUTRAL for about 5 seconds, and the clunking should be less.
CJ7-Tim is offline
post #3 of 7 Old 06-05-2013, 08:10 PM
dmill89
1995 XJ Cherokee
X2 on the U-joints, also check the transmission mount it is often a combination of the two, the u-joint allows the movement and a worn transmission mount amplifies it and makes it more noticeable.
dmill89 is offline
post #4 of 7 Old 06-06-2013, 05:28 PM Thread Starter
HawksWin
Very good, so its nothing I should be overly concerned about?
Thanks guys,
Trevor
HawksWin is offline
post #5 of 7 Old 06-06-2013, 05:45 PM
dmill89
1995 XJ Cherokee
Thanks guys,
Trevor
Don't be deathly concerned, but don't let it go either. Sooner or later those U-Joints will fail if not replaced and your drive shaft will go bouncing down the road behind you.
dmill89 is offline
post #6 of 7 Old 06-07-2013, 03:40 PM
CCKen
CCKen's Avatar
Pull the drive shaft and see if the yoke splines need grease. Use a cable tie to reattach the rubber boot to the shaft.
If you need u-joints, use Dana-Spicer u-joints.
Replace the u-joint clamps and bolts with new parts when going back together.
Edit: Before removing the drive shaft, paint an alignment mark on the drive shaft yoke and the rear differential pinion yoke for reference at reassembly.
CCKen is offline
post #7 of 7 Old 06-07-2013, 04:05 PM
wgirvine
1992 XJ Cherokee
There should be ZERO play in the U-joints.
The road goes on forever, the party never ends....
wgirvine is offline
