Quantcast clunk clunk, my front axle goes clunk (when turning left with accellerator pressed) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > clunk clunk, my front axle goes clunk (when turning left with accellerator pressed)
Old 01-14-2006, 08:40 PM   #1
asjeep
The title pretty much says it....
took it to 2 local shops,
1 told me it was my passenger side axle ujoint, and the wheel bearings in that side
the other shop told me it was the passenger side ujoint and the drivers side ujoint
so i head home.... poceed to pull my axles, and what do i find? nothing....
the ujoints are all free moving, not jammed stuck etc, no play if they werent dirty and rusty... i would say they were almost new.....
so check the hub bearings (all looks good, and no play when i have a tire on it either....
any bright ideas? it is still clunking..... Oh and just replaced front rotors and pads.....
2002 TJ SE
WWW.IDRIVEAJEEP.COM
asjeep is offline   Reply With Quote
Old 01-14-2006, 10:05 PM   #2
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Mine did the same thing. It drove me nuts trying to figure out what it was. Everything was in good shape and torqued to spec. It just went away one day. I never did figure out what it was.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 01-14-2006, 10:19 PM   #3
asjeep
Now that scares me
some addl info.......
when coasting, no problem,
when in 4wd same issue as in 2wd
the klunk does not seem to speed up when accelerating and turning, even if i go faster.....
2002 TJ SE
WWW.IDRIVEAJEEP.COM
Old 01-14-2006, 10:38 PM   #4
Matt Gertsch
www.lp.org
Originally Posted by asjeep
Now that scares me
Its cool. I doesn't do it anymore.
Roger Waters
Old 01-14-2006, 10:44 PM   #5
jeepsurfgirls
Is that when your 4wd or 2wd?
"Your not Jeepin until you get stuck"
"Im not jeepin unless i break something"
jeepsurfgirls is offline   Reply With Quote
Old 01-14-2006, 10:44 PM   #6
asjeep
Originally Posted by jeepsurfgirls
Thats when your 4x4 right?
sorry just edited, 4wd, or 2wd
2002 TJ SE
WWW.IDRIVEAJEEP.COM
Old 01-14-2006, 10:57 PM   #7
jeepsurfgirls
Idk
I beend told front u-joints to and that the same issue im having with my jeep so im goanna try doing the u joints this weekend. My front u joints also look solid and dont seem to have any play in them. So im goanna try replacing them this weekend if i can get around to it.
Old 01-14-2006, 10:59 PM   #8
asjeep
i physically yanked the axles and checked them, they look ok.... i put it back together, figure i can take it back apart easy enough........
2002 TJ SE
WWW.IDRIVEAJEEP.COM
Old 01-14-2006, 11:17 PM   #9
Matt Gertsch
www.lp.org
Mine did it in 2x or 4x also. A lot of forum members told me it might be track bar related. I couldn't find anything though.
Roger Waters
Old 01-15-2006, 12:11 AM   #10
asjeep
hmmm trackbar..... i did notice a bushing missing from a front swaybar link.... perhaps i will try to pull it (cut it off)
2002 TJ SE
WWW.IDRIVEAJEEP.COM
Old 01-15-2006, 01:38 PM   #11
Matt Gertsch
www.lp.org
I'd keep the front sway bar in place. Just replace the bushing.
Roger Waters
Glock Forum
