Climate Control Mod Help - JeepForum.com
post #1 of 11 Old 08-06-2013, 09:31 PM Thread Starter
Trombly
I remember a long time ago running across a mod that let the driver control when the AC compressor turned on, a.k.a. you put a switch in to kill the power to the compressor when you were using defrost, anyone have a link?
thanks
Trombly is offline
post #2 of 11 Old 08-07-2013, 04:34 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Ask the guys in Charley's thread, they were just talking about that a couple of days ago. http://www.jeepforum.com/my-goal-get-25-mpg-my-99-xj
***Chris***
chris87xj is offline
post #3 of 11 Old 08-10-2013, 09:54 PM
sAe23
1995 XJ Cherokee
A/C makes the defrost more effective (by dehumidifying the air). Are you trying to hypermile like some here are trying to do?
sAe23 is offline
post #4 of 11 Old 08-15-2013, 10:46 PM Thread Starter
Trombly
I just don't like compressor turning on lol
Trombly is offline
post #5 of 11 Old 08-16-2013, 07:46 PM
ECL
Just unplug the wiring harness at the compressor. Without 12volts to the magnet, the clutch won't engage,
ECL is offline
post #6 of 11 Old 08-17-2013, 06:03 AM
xjman242
I feel thats not a very good idea at all! (1) mentioned above your defrost will not work as well as it should.(2) without your compressor" pump" never spinning things are going to start drying up,[ie] the vanes in the pump,o-rings,ect. If you're looking to improve fuel consumption look in to removing the mechanical fan with another electric....a popular/cheap swap is the from a Ford Taurus. Just a suggestion
xjman242 is offline
post #7 of 11 Old 09-11-2013, 02:09 AM
mayeni
1992 XJ Cherokee
What about putting a switch into the low pressure switch circuit? I think that would work, and it seems to be a low current circuit.
mayeni is offline
post #8 of 11 Old 09-11-2013, 05:14 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If you want to get better mileage, get one of these: And then drive using the tips below.
http://www.ehow.com/how_8098066_driv...-gasoline.html
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #9 of 11 Old 09-11-2013, 01:44 PM
sAe23
1995 XJ Cherokee
Or, just realize that any time you are accelerating, you are sucking gas...
sAe23 is offline
post #10 of 11 Old 09-11-2013, 03:03 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That's a good "visual" a vacuum gauge gives ya. While driving with clear windshield to boot.
post #11 of 11 Old 09-13-2013, 09:28 PM Thread Starter
Trombly
Ya I'm gonna do the electric fan swap, the vacuum gauge is a good idea too. I'm gonna wait on the AC idea.
Thanks guys! Rock on!
Trombly is offline
