clicking sound when turning - JeepForum.com
post #1 of 10 Old 04-07-2002, 12:25 PM Thread Starter
jsc1648
1995 XJ Cherokee
Post clicking sound when turning
I have a 95 Cherokee Sport 2wd with 84k and when I turn the steering wheel at low speed/no speed I hear a clicking sound from the front suspension area as well as kind of feel it in the wheel. It's been happening for about 6 months now and seems to be getting worse. It will happen almost every time I pull in/out of a parking spot. It seemed to get worse when I replace the front wheel bearings. I took it to a shop and they though it was a worn out ball joint. Any ideas?
jsc1648 is offline
post #2 of 10 Old 04-07-2002, 07:47 PM
CB89XJ
Post
Grease up the trac-bar REALLY REALLY good. This basically took my noise like that away. There is a little grease fitting you will see where the upper part of the trac bar attaches.
Colin Beatty
'87 YJ, built 351W, T-18, NP-205, SOA, SRS, 35x12.50 ProComp MT's, cage, winch, Tomken bumper/carrier, d44/9"
www.bmja.org
CB89XJ is offline
post #3 of 10 Old 04-08-2002, 11:22 PM Thread Starter
jsc1648
1995 XJ Cherokee
Post
Done that and it seems to have no effect for some reason. Unless i'm missing it. I typically grease 5 fittings under there. Am i missing something????
jsc1648 is offline
post #4 of 10 Old 04-09-2002, 12:01 PM
J-Mac
Arrow
When I had the same problem and it got real bad, it turned out that the bracket that the top of the trac bar bolts into was at fault. The hole at the bottom of the bracket that the trac bar attaches too was barrowed out, aka it had warn to be slightly larger than it was supposed to be. This is what caused the noise. I had to replace the bracket, about $100 and it is an easy job. I hope this helps.
1997 XJ Sport 4x4 power toys 5" lift 31x10.50's...NOT!!
Time flies- Now its on 6.5" with 32x11.50's that look SMALL!
if you're gonna talk about it be about it
J-Mac is offline
post #5 of 10 Old 04-09-2002, 06:25 PM
O-Gauge Steamer
Post
If you have automatic hubs, these can be the culprit. The lousy spring does not always completely disengage the hub. Yep, my '97 XJ sometimes does this also...
O-Gauge Steamer
because there are other things to do...
97 XJ, 3"RE lift, 4-wheel disk brakes, Skid Row Xfr case skid plate, Avenger 4x4 welded LCA armour, Avenger 4x4 Rock Rails and a long wish list...
O-Gauge Steamer is offline
post #6 of 10 Old 04-10-2002, 08:38 PM Thread Starter
jsc1648
1995 XJ Cherokee
Post
Its 2wd, so i'm sure auto hubs are not the prob
jsc1648 is offline
post #7 of 10 Old 04-11-2002, 06:56 AM
PrimeSuspect
Lightbulb
Check the U-Joints.
PrimeSuspect is offline
post #8 of 10 Old 04-14-2002, 02:54 PM
amaple
Post
I had the same problem and it required replacing my cv joints. kind of expensive. Speaking of turning problems, whenever I make left-hand turns over ten mph while using the brakes, I get a non-metallic rubbing noise. Any ideas?
adam.
1993 Cherokee Country ** Rubicon Express 3" Super-Flex lift ** 1.5" Rusty's extended rear shackles ** Rusty's exhaust ** Wilderness Roof Rack ** BFG A/T KO 31's ** Brand new 4.2L engine ---
1974 CJ-5 ** dual Dana 44s ** only 55,000 original miles! ** no mods yet
Adam
amaple is offline
post #9 of 10 Old 04-15-2002, 08:57 PM Thread Starter
jsc1648
1995 XJ Cherokee
Post
It's not 4wd. I doubt CV joints are the problem....
jsc1648 is offline
post #10 of 10 Old 03-07-2004, 10:06 PM
walker_a_d
Question
I have exactly this same problem with my 2wd '93 - When the steering wheel is turned, to pull into the garage or a parking space, something (I think in the front end) clicks and keeps on clicking until the wheel is straightened.
If I hit the brakes to come to a complete stop while the steering wheel is still turned, the clicking stops the same time the wheels stop turning, and if I inch forward even just a couple of inches, it clicks again.
If I go a little faster with the steering wheel still turned, it clicks rapidly. It's about the same in both directions. I looked for anything catching or rubbing or making contact but could not find anything.
Did you figure out what the problem was? maybe whatever worked for the original poster would work for me too.
Or anybody have any further ideas? I will take a look at the track bar as somebody up above mentioned.
Thanks!!
93 Cherokee Sport 4.0L HO 2wd
walker_a_d is offline
Clicking when Turning JeepDVL45 XJ Cherokee Technical Forum 10 08-21-2009 09:32 AM
Clicking from front when turning JGoad2 XJ Cherokee Technical Forum 8 04-11-2007 04:30 PM
clicking when turning isenegger XJ Cherokee Technical Forum 2 10-08-2006 09:16 AM
Help with clicking noise when turning? walker_a_d XJ Cherokee Technical Forum 4 03-09-2004 11:29 AM
Clicking Noise when turning IntrepidXJ XJ Cherokee Technical Forum 1 06-29-2003 09:04 PM
