Quantcast Cleaning the Engine? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Cleaning the Engine?
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 11-11-2007, 06:24 AM   #1
lilseth0014
1997 XJ Cherokee
What is the best way of cleaning your engine compartment withou doing any harm to it. There is a lot of dirt and mud over everything. Can i just hose it down at the car wash with the engine cleaner choice? Or should i be a bit more carful and do it myself at home?
lilseth0014 is offline   Reply With Quote
Old 11-11-2007, 07:31 AM   #2
88XJSport
1988 XJ Cherokee
If water hits the Throttle Position Sensor, it will most likely kill it, and the trans will stay in first gear.
88XJSport is offline   Reply With Quote
Old 11-11-2007, 08:20 AM   #3
Me007gold
cover your alt, cover your bat and air box. spray with simple green, rinse off with hose. repeat if desired
Me007gold is offline   Reply With Quote
Old 11-11-2007, 10:34 AM   #4
cox_xj
1997 XJ Cherokee
thats funny........and so wrong lol.......
clean it how you want, dont use to much pressure or any harsh chemicals, if **** does get wet (ie alt etc) keep the truck running for awhile, so the heat will dry it out
i ususally clean my motor with them running, get them warm start spraying your cleaner, then hose off, never had any problems
cox_xj is offline   Reply With Quote
Old 11-11-2007, 10:38 AM   #5
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Not that wrong. Some people have posted that using high pressure when washing the engine killed one or more of the sensors.
The best way to clean under the hood is to spray some Simple Green cleaner on a warm ( not hot ) motor and use the hose to wash off the dirt and grease. Allow the water to run out of the hose, never squirt, spray or use high pressure and everything will be clean and happy.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 11-11-2007, 10:41 AM   #6
cox_xj
1997 XJ Cherokee
well yeah if you pressure wash it you'll mess stuff up, but you dont need to pressure wash it, just get a good cleaner and do a few light washes
hell when it starts raining again my hoods coming off for awhile, and i'ma steam clean it while driving, the BEST way i've found, may be illegal in some places but my nissan had the cleanest engine bay in town
Old 11-11-2007, 11:31 AM   #7
88XJSport
1988 XJ Cherokee
Try pouring a bottle or so of water, cleaner, any liquid on yours, and post back the results.
Thanks.
And how can you debunk something that I have done? I barely got it wet with a garden hose and killed it.
Old 11-11-2007, 11:37 AM   #8
xjpilot
I power wash mine at the car wash all the time. Spray some of their engine cleaner on it, was the rest, and come back and hit it with rinse. Granted I usually give it about 2-3 ft between the nozzle and the engine, but I've never had one problem. Now I just need to figure out how to get the mud stains off of all the rubber on my jeep?
my jeep has the confused prerunner syndrome....4.5" in the rear and 2" in the front.
Purple Jeep Club Member # 1
xjpilot is offline   Reply With Quote
Old 11-11-2007, 12:00 PM   #9
cox_xj
1997 XJ Cherokee
Thanks.
i just hosed down my entire motor, and nothing got messed up
something else must have been wrong with yours, maybe the seal on the sensor was bad, idk, but mine survived, as would most if they are in good condition
Old 11-11-2007, 12:31 PM   #10
88XJSport
1988 XJ Cherokee
Maybe the HO motor has a more water tight TPS. If thats the case consider yourself lucky.
Old 11-11-2007, 12:34 PM   #11
cox_xj
1997 XJ Cherokee
could be, i wasn't trying to call you out or bash you man, just my experience with getting motors wet, a lil water never hurt anything...cept oil lol
Old 11-11-2007, 12:48 PM   #12
88XJSport
1988 XJ Cherokee
could be, i wasn't trying to call you out or bash you man, just my experience with getting motors wet.
No harm no foul bro.
Glock Forum
