Cleaning A/C Clutch? - JeepForum.com
post #1 of 8 Old 12-27-2012, 06:02 AM Thread Starter
cactus_jack
Not sure if you guys remember, but way back in the day I swamped my Jeep. Ever since then, my A/C compressor has had a constant whine. It only makes this whine when the clutch is disengaged. When I turn the A/C on, the clutch engages and doesn't make any noise.
After months of putting up with it, I'm sick of the noise. My XJ sounds like one of those old Dodge Caravans with the whiny PS pump. I can only assume one of two things:
1. Clutch plate is just dirty
2. Some sort of bearing is shot and is about to lock up
What do you guys think?
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #2 of 8 Old 12-27-2012, 01:35 PM
AZ Jeff
2014 JK Wrangler
There is a bearing in the hub of the pulley. It only turns when the clutch is DISENGAGED. That sounds like your issue.
Pull the belt and spin the pulley by hand and listen for noise or roughness.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 8 Old 12-27-2012, 03:21 PM
squirlgod
you can take off the clutch plate and take a look. You'll need a special tool though that you can usually rent at an autoparts store. If the Bearing is shot, you got more luck with a new compressor I think...hard to find just the pully
"Yeah....It's Purple."
squirlgod is offline
post #4 of 8 Old 12-27-2012, 07:48 PM Thread Starter
cactus_jack
Figured it was the bearing but was hoping someone had a similar issue and had a quick fix. Lucky for me, I run a NAPA store so it wont hurt my wallet as bad, lol
CACTUS_JACK
post #5 of 8 Old 12-27-2012, 08:48 PM
trunk3d
Just walked back into the house from changing my compressor on a 2000 model.. Very easy to do; the most tedious procedure was the serpentine belt. :-)
trunk3d is offline
post #6 of 8 Old 12-27-2012, 09:50 PM
AZ Jeff
2014 JK Wrangler
You can get just the bearing and install it in the pulley yourself. Here is a source:
AutoAirOnline.com. Phone is 1 800 726 2310
AZ-Jeff
AZ Jeff is offline
post #7 of 8 Old 12-28-2012, 06:41 AM Thread Starter
cactus_jack
I had thought about that. Thanks for doing the leg work for me! lol. Honestly, if they can give me a part number, I'll just cross it at work and get one there.
CACTUS_JACK
post #8 of 8 Old 12-28-2012, 01:22 PM
Kalali
Hmmm. I just posted a new thread about this before I saw this one. I see the clutch bearing for $33 which sounds real reasonable. Do I need a special tool to remove the pulley and install the new bearing? Please let me know how you make out doing your repair. I need to do the same exact job.
Thanks,
Kalali is offline
