Chrysler 8.25 vs Dana 35? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Chrysler 8.25 vs Dana 35?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 11-21-2008, 02:14 PM   #1
Mr_Clickerson
1994 XJ Cherokee
I just found out, after thinking I had a Dana 35 in my rear end, that I have a Chrysler 8.25... I was a bit suspicious when I noticed the rear axle tubes looked much larger than the front, which I was almost certain was a Dana 35...
What I want to know, is how much better, if at all, are the Chrysler 8.25 over the D35? I ask because I've heard of people swapping them in over a D35.
Originally Posted by Lamb of God
Whoever appeals to the law against his fellow man is either a fool or a coward; whoever cannot take care of himself without that law is both. For wounded man shall say to his assailant, "if I live, I will kill you- if I die, you are forgiven;" such as the rule of honor.
Mr_Clickerson is offline   Reply With Quote
Unread 11-21-2008, 02:15 PM   #2
dagen
from what i remember the axle tubes are slightly thicker.
seems to be the consensus that the 8.25 is stronger. not by a lot, but enough.
dagen is offline   Reply With Quote
Unread 11-21-2008, 02:16 PM   #3
GPV
The 8.25 is better than the Dana 35. Not as good as the Dana 44. IMHO
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline   Reply With Quote
Unread 11-21-2008, 02:19 PM   #4
xjfever
1995 XJ Cherokee
If you have the origional 94 model 8.25 it is 27 splined, and a bit stronger than the dana 35. But the 97 and up 8.25 is 29 splined axles, and compareable to the dana44.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Unread 11-21-2008, 02:19 PM   #5
xGArfx
since im assuming u have the pre 97 xj that u have the 8.25 with the 27 spline shafts which basically isnt much stronger the the d35... u could always just swap in some larger spline shafts. just got to a upull yard nd see if u can find a 97+ xj with the 8.25 cus those came with 29 spline shafts which can easily handle 33s locked even 35s with some chromo shafts might as well just grab the whole axle nd just swap it
xGArfx is offline   Reply With Quote
Unread 11-21-2008, 02:21 PM   #6
justanotherjpr
The 8.25 you have is only marginally stronger than the Dana 35. Your 8.25 still has 27 spline shafts. The 8.25 from 97+ Cherokees have 29 spine shafts, and are substantially stronger. You should be able to buy a locker for the 29spline 8.25 and 29spline shafts and put them into your carrier. Some say you have to change the carrier over as well. I have never personally tried this, so I do not know.
The other advantages of your 8.25 over the D35 is the stregnth of the housing, gears, tubes, and carrier. All of the aforementioned are bigger and stronger than the D35.
Your front axle, if stock, is a Dana 30.
justanotherjpr is offline   Reply With Quote
Unread 11-21-2008, 02:24 PM   #7
Mr_Clickerson
1994 XJ Cherokee
Thanks a lot guys! Quite a wealth of information.
Unread 11-21-2008, 02:33 PM   #8
4.0H.O.XJ
Many, MANY 96's came with 29 spline 8.25's. I have only ever seen ONE 27 splined 96. I think early build date 96's came with maybe a few 27's. We need to put this myth to bed.
4.0H.O.XJ is offline   Reply With Quote
Unread 11-21-2008, 02:34 PM   #9
96cherokeeclass
XJ axles are semi float unless you do the hub conversion on the front, but either way use 1541h shafts in the rear, not chromoly... or they will snap
- 07 WK - CRD
96cherokeeclass is offline   Reply With Quote
Unread 11-21-2008, 02:36 PM   #10
96cherokeeclass
You know I have heard this, I've got my 8.25 from my 96 sitting in the shop. I need to get off my lazy ____ and check the spline count.
- 07 WK - CRD
Unread 11-21-2008, 02:44 PM   #11
Magus2727
1995 XJ Cherokee
i just saw a jeep with a D35 in the back... that thing looks tiny next to a C8.25... I did not think there was that much of a differance but the tubes half to be at leas 1" smaller on the D35 then the C8.25
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline   Reply With Quote
Unread 11-21-2008, 05:59 PM   #12
Rough Country
dana 35 tube is 2 3/4in c 8.25 is 3in tube diameter
Rough Country is offline   Reply With Quote
Unread 11-21-2008, 06:08 PM   #13
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
What myth? I'll reiterate this again here...every 96 ive seen and have had the opportunity of knowing about, has had 27 splines.
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline   Reply With Quote
Unread 11-21-2008, 06:20 PM   #14
MBJR9
Everyone else has basically summed it up. The pre '97 8.25's are only 27 spline and are comparable to the the Dana 35. The '97 and later 8.25's are stronger and thus more desireable than Dana 35.
However, the Dana 35 will be good up to a 31" or 32" tire. After that you need to start thinking of upgrades.
The XJ
1996 XJ Sport, 4.0L HO I6, AX15 5 Speed, NP231, Dana 30/35, Flareless
The Daily Driver
2004 Ram 1500, 5.7L Hemi V8, 545RFE 5 Speed Auto, NP241, Chrysler 8.0/Chrysler 9.25, 10mpg
MBJR9 is offline   Reply With Quote
Unread 11-21-2008, 06:24 PM   #15
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
The only 96's with 29 spline shafts are the LATE model build units. The one I know about was a November built one.
The 27spline 8.25 is a stronger axle than the D35.
The ring gear is 8.25 verses the D35 7.62.
The 8.25 pinion is the same dia as the D60.
The 8.25 axle tubes are thicker and stronger than the D35.
It's not as strong as the 97+ 8.25, but IMO it's stronger than the D35. One of the biggest down sides to the D35 is the axle tube flex. That flex puts stress on the internals as well as the shafts. Any time someone asks about a Super35 kit, I recommend they truss the axle as well.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
