Chrysler 8.25 vs Dana 35 - JeepForum.com
post #1 of 9 Old 03-12-2012, 03:25 PM Thread Starter
whitetrash
1997 XJ Cherokee
What are the advantages of a Chrysler 8.25 over the Dana 35 rear axle? I plan to take it off road, but I don't plan to modify it much (I run 235/75 instead of 225/65, but everything else is stock). I'm not really a recreational off-roader... but as an avid hunter, I need a ride than can handle itself off the beaten path. Most of my driving is on pavement, though. I hear the Chrysler is tougher, but is it necessary if I don't plan to jack it up and rock crawl with it?
Thanks!
whitetrash is offline
post #2 of 9 Old 03-12-2012, 03:28 PM
chriskeenan
for your uses the d35 is perfectly fine.
chriskeenan is offline
post #3 of 9 Old 03-12-2012, 04:11 PM
jeepnphreak
1989 XJ Cherokee
the cry 8.25 is on par with a dana 44. it can handle 33 or 35 in tires.
but for you with 235s a d35 will be fine.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #4 of 9 Old 03-12-2012, 05:17 PM
rondak46
The 8.25 is a great upgrade from a D35. Get one out of a Cherokee, 97-01 I believe and it will have 29 splines. Aftermarket support is limited, but growing. Also, It does not support ABS.
I would run an 8.25 over an 8.8. I like the flat Diff bottom, threaded adjustment for backlash, better clearance than an 8.8 or D44, huge tubes, and the Pinion is not ridiculously offset like an 8.8.
rondak46 is offline
post #5 of 9 Old 03-13-2012, 03:01 AM
jeepeexj
Going to the 8.25 you would loose ABS. Agree with previous post that the D35 is more than fine with that tire size
jeepeexj is offline
post #6 of 9 Old 04-21-2012, 03:24 PM
chrometracker
How about the same scenario with 30's 0r 31's and a 2" lift. Will the d35 still be sufficient?
chrometracker is offline
post #7 of 9 Old 04-21-2012, 03:31 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I have watched several stock Jeeps break a D35 with stock car type P metric size tires. The Chry 8.25 is easy to find, cheap, has lockers available, will accept disk brakes, and is much stronger than a D35. If you have durability concerns, find and install an 8.25. As noted, the 8.25 does not support ABS, but that is no big loss. Simply pull the ABS relays and ABS is disabled.
CJ7-Tim is offline
post #8 of 9 Old 04-21-2012, 07:08 PM
Hudson
Dana 35 - 27 Spline
Chrysler 8.25 - 29 Spline + bigger axle tubes + easy to find. Doesn't support ABS.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #9 of 9 Old 04-23-2012, 10:43 AM
ingenio
Thanks!
For your application, don't even worry for the D35.
if some day you think you need to change pinion & ring in your D35, then replace the whole axle with a 8.25 w/29 splines...(97+ Xjs)
ingenio is offline
axle , chrysler 8.25 , dana 35
Chrysler 8.25 vs Dana 35? Mr_Clickerson XJ Cherokee Technical Forum 43 12-01-2014 11:04 AM
Dana 35 or Chrysler 8.25 ??? r6dink XJ Cherokee Technical Forum 28 03-06-2007 12:21 AM
Chrysler 8.25 vs Dana 35 bultacco XJ Cherokee Technical Forum 8 11-25-2006 08:34 AM
Dana 35 or a Chrysler 8 1/4 89Cherokee4x4 XJ Cherokee Technical Forum 8 08-17-2006 01:24 AM
Dana 35 V.S. Chrysler 8.25 white98xj XJ Cherokee Technical Forum 25 02-26-2006 10:07 PM
