Chrys 8.25 LSD? - JeepForum.com
post #1 of 12 Old 08-10-2013, 11:04 PM Thread Starter
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Chrys 8.25 LSD?
Today I could not pass up buying our new 92 XJ. It has a factory Chrysler 8,25 rear end. The seller stated it was a limited slip diff, but nothing I have found here says it could be. Anyone know if these 8.25s were ever produced in a LSD configuration?
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #2 of 12 Old 08-10-2013, 11:05 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Yes, the Chry 8.25 was available with optional LS.
CJ7-Tim is offline
post #3 of 12 Old 08-10-2013, 11:13 PM Thread Starter
Luuca
Luuca's Avatar
Thank you!! I'm doing a complete fluids service and that's important when selecting the rear diff fluid. If I jack up one side of the rear, and spin the tire, it should produce some friction - Correct? Or is there a better way to confirm the LSD?
YJOTM never
Luuca is offline
post #4 of 12 Old 08-10-2013, 11:21 PM
X-Rated
If its a lsd when you jack it up and hand spin the tire the opposite side tire will turn in the same direction.
If the opposite tire turns the other direction its an open diff,
X-Rated is offline
post #5 of 12 Old 08-10-2013, 11:41 PM Thread Starter
Luuca
Luuca's Avatar
Sweet! Thanks again! I knew there was some way to confirm it.
YJOTM never
Luuca is offline
post #6 of 12 Old 08-10-2013, 11:52 PM
X-Rated
No problem
Hope you have the lsd, its a pretty good unit and congrats on your new XJ!
X-Rated is offline
post #7 of 12 Old 08-11-2013, 01:46 AM
Hudson
Easier to find a patch of grass and hit the skinny pedal.
one tire mark = no LSD
two tire marks = LSD.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #8 of 12 Old 08-11-2013, 02:45 AM
xj2k1
If you're changing the fluids, you'll be removing the diff. covers. My '01 XJ came from the factory with a Chrysler 8.25 Trac-Lok(Limited slip). What I've learned about digital cameras is, that you'll take pictures of crap you would have never wasted film on before. With that in mind. Here's a picture of the front and rear diffs. on my XJ. Again, the rear is a Chrysler 8.25 limited slip(2001). You could also have a Chrysler/Jeep dealer run your VIN, and they could tell you what it came with from the factory.
xj2k1 is offline
post #9 of 12 Old 08-11-2013, 03:57 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sounds pretty destructive just to avoid popping the cover.
Anticanman is offline
post #10 of 12 Old 08-11-2013, 05:22 AM
bobthecatkiller
Not really... It's not like he said to do it on pavement.
Also I had a Sticker in my glove box
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #11 of 12 Old 08-11-2013, 07:43 AM
CJ7-Tim
CJ7-Tim's Avatar
Most xJ's with factory installed LS had a sticker on the glove box and a tag on the differential cover. My 2000 with LS had neither sticker nor axle tag when I bought it. Over time one or both can become lost.
A quick burn-out on grass or dirt should show what diff you have. If you still are not sure, buy a bottle of Limited Slip Friction Modifier and look inside when you change the gear oil.
Open diff on the left, Limited Slip on the right.
CJ7-Tim is offline
post #12 of 12 Old 08-11-2013, 07:59 AM
JMH21814
1997 XJ Cherokee
I have a 97 with the open 8.25. Just got my lsd carrier to do a swap. I'm stoked. Got my XJ last winter and every time I went to pull out onto the main drag I'd be on half ice and half dry pavement. I'd have to throw it into 4H just to avoid getting hit, or if no one was coming, then I could do a 1 legger til I hit pavement and shock the hell out of my drivetrain... well, this winter'll be different, that's for sure.
JMH21814 is offline
