#1 | |
Chopped top question
To begin with, I am a new member and would like to say hello to all of you. I am 17 and bought a 96 xj this past winter. Since buying it, I have become entangled in a state of endless modifications which has brought me to this inquiry.
I have a question about chopping the rear off of my 96 cherokee country. I want to remove the top from the front of the rear windows back, if that makes any sense to you. I have seen a few people on this and other forums who have done so. The question I have is about structural stability. I plan on leaving the lower part of my liftgate as a kind of makeshift tail gate. I want to bolt or weld that in place. My question is, would the vehicle be structurally sound enough? It is my guess that with that bolted in place, and the fact that I have a tow hitch, which is tied into both unibody rails, that it would be of adequate strength. I do not do any heavy wheeling, only driving forest roads and some very light trails, nothing that has ever had me worried about my vehicle's structural state. Would it be safe to do what I am planning, or would it be absolutely necessary to put a cage in? I'd like to thank you all for your help, it is much appreciated.
I'm not an actor. I just play one on tv. |
#2 |
www.lp.org
It would have the structural integrity of a cardboard box if you didn't cage it.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? " Roger Waters |
#3 |
fiberglass doesnt weld too well.
and if you plan on wheeling it invest in a cage, if you drive it on the street, it might hold up ok, but to be safe, cage it.
97 xj 44 front, detroit, alloyed 60 rear, detroit, 35 spline alloyed 35" beadlocked km2's 3" midarmed more bells and whistles than you can shake a stick at |
#4 |
check the desert metal build sheet...he just chopped his...
the 96 is the year they upgraded the strength of unibody and stronger bars...and if you have a country that should mean you have a 4 door which means it should be stronger than a two door...main pillars...so chop ahead, you beat me to chop my 96...but also id cage it if you are gonna be leaning or tipping your heap... what kinda lift do you have on it too?
87 XJ pioneer-Totalled 96 XJ Sport- Sold Now: 88 RENIX 4.0 XJ, Project Overlander 3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats |
#5 |
It's a country I might add. I'd say it sees about 90% on road driving, with the occasional camping trip (forest roads, flat minnesota trails).
It's got 3" rough country springs up front, and the rear sits a little higher than 3" with the s-10 packs i've got in it.
#6 |
Resident McGeek
I would cage it regardless. If you are ever in an accident with no cage, you will prob be killed and your insurance company will never cover it.
Kyle - I tag stuff® 2000 Jeep XJ - Chopped / Locked Join the XJ Owners Club | Download the iMarn® iPhone App!1997 Jeep XJ - Daily Driver 2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather! Homepage | Jeepspace Group|Twitter!|Facebook |
#7 |
This is probably a stupid question, but to cage of the rear where would be the best places to put support? I've done some searching, and all the pictures I see of chopped xjs have either no support, or cages that go around the entire vehicle. Would that much cage be necessary, or would a few strategically placed bars be adequate?
Forgive the lack of experience, I'd just like to do it the right way when I do go through with it.
#8 |
research, alot.
ive been reading cage threads on www.naxja.org for about a year now and i still dont know if im ready to tackle it.
#9 | |
Resident McGeek
Hope that helps, do your research!
#10 |
Forum God
the jeep is absolutely not going to need a cage to drive around. but as kyle stated, accidents and stuff change that. you should definitely invest at bare minimum in stuff which was already mentioned. You dont need a full on cage, just something to replace the rigidity which was lost, so some cross-brace support and up and downs at the pillers
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me; Thy lift and thy tires, they comfort me. Thou preparest a spotter before me in the presence of mine obstacles; |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
