Quantcast Chevy 350 swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Chevy 350 swap
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 09-10-2006, 04:38 PM   #1
89'XJ
Chevy 350 swap
Ok I got a idea for my 89 XJ. I want to give it some muscle with a chevy 350 but I do beleive that I have to swap out my tranny and transfer case along with it. And I want to put a ford 9" in the rear and a Dana 44 in the front with a driverside dif. My question is what manual transmission and transfer case could I use?
89'XJ is offline   Reply With Quote
Old 09-10-2006, 05:34 PM   #2
olds442
im not saying u shouldnt do it, but a friend of mine put one in his cj7 and cant stand it, if ur climbing at all or not level the thing stalls out so much
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
olds442 is offline   Reply With Quote
Old 09-10-2006, 05:56 PM   #3
89'XJ
Is his Fuel injected or carborated?
Zack Miller
Lift it, fat chicks can't jump.
89' XJ Laredo 2dr 4" lift 4.0L 31"x10.5" bfgoodrich
Old 09-10-2006, 05:59 PM   #4
Cerealdaemon
1988 FSJ Wagoneer
from the description, I'm guessing carbureated, I don't know of any EFI engines that do that.
As for what kinds of components, the ford 9 and d44 sound good, the Atlas 2 is a sweet TC and I'm not able to speak about the tranny, I don't know too much about transmissions.
You CAN use anything you want, but what you should use are the best components that you can afford
"stand over and deliver, or the Devil he may take ya!"
Cerealdaemon is offline   Reply With Quote
Old 09-10-2006, 06:04 PM   #5
olds442
its not fuel injected
Family Wheelin...
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
Old 09-10-2006, 07:40 PM   #6
89'XJ
Yeah I dont think I would have a budget for an Atlas, I heard that a for np208 works but I dont know if it would match up with a chevy tranny.
Zack Miller
Old 09-10-2006, 08:00 PM   #7
Cerealdaemon
1988 FSJ Wagoneer
as far as I know, you can match any transfer case to any tranny, providing that you can get or make an adapter for the different spline counts
find a 231 out of an older model jeep anything, they are very reliable and your jeep probably already has one. nothing wrong with them.
Old 09-10-2006, 08:22 PM   #8
sharpie
German car snob
sharpie's Avatar
1999
from what I remember, the 302 is the largest Chevy motor that will go in the engine bay without MAJOR modification.
- Brian
Klein Concept and Design
KCD Website
Follow us on Facebook!
XJ Writeups:
| DOORLESS IN A 97+ | D44 SWAP | REBUILDING A CV DRIVESHAFT | HOME-BREWED CENTER CONSOLE
sharpie is offline   Reply With Quote
Old 09-10-2006, 08:26 PM   #9
bandit88
chevy hasnt made a 302 in years,plus any smallblock has the same block size
88 xj chief (ex conservation vehicle),4.0,aw4,np231,danas..35-r..30-f ,all new brake components
3 inch lift,flareless,trimmed fenders 31x10x50 maxxis mudders,galaxy 88 export c.b.,102 inch steel whip,dx 1600 linear(sweet sixteen)
bandit88 is offline   Reply With Quote
Old 09-10-2006, 08:27 PM   #10
knatdog55
1990 XJ Cherokee
although they should have kept the 302 instead of going to a 305, i've had 3 vehicles with the 305 and they are hurting for power big time!
Master of Custodial Arts-Serving the Navy one clean floor at a time.
[url]www.tgc4x4.com[/url]
[QUOTE=Name Protected]Should a Compass ever actually see any offroad conditions, they magnitude of attraction would be so great that it would surely burst into flames causing the driver to vear into the nearest tree...this would cause massive forest fires that would eventually lead to the burning down of many houses, and possibly members of this forum.[/QUOTE]
knatdog55 is offline   Reply With Quote
Old 09-10-2006, 08:30 PM   #11
89'XJ
Cool knowing that the Tcase should'nt be much of a problem. I know that a 350 is a tight fit, but I've seen it done before I know that it must be lifted more than 3" so I'm good there but I should probably pull some measurments from a engine to get a better idea for it. As far as a manual tranny what would be a good pick I would want a 3 or 4 speed but I have been having trouble getting good specs. on anything.
Zack Miller
Old 09-10-2006, 08:30 PM   #12
JJXJ
The blocks are almost the exacts same size between the 305 and the 350. You can stroke a 350 to a 383. I've seen a 383 in a lifted 98 XJ. It fit fine...He was running a TH-350 and a NP-205 btw...
1997 XJ Sport-Dark Blue-4.0-AW4-NP 231-235/75R15 Delta Mud Tracs-ConFerr Roof Rack w/4 Baja's up front and 2 Optronics fogs for back up lights-Dynomax Catback-Banks header!-Bulldog remote starter-Sony Atrac3 Deck-10" 200 watt Bazooka
[url]http://www.myspace.com/amdapmulisha[/url]
JJXJ is offline   Reply With Quote
Old 09-10-2006, 08:50 PM   #13
DreamsOfMoab
Location: Colorado Springs/People's Republic of Boulder, CO
Go for TH400 and Atlas II (If youre gonna wheel it)
Colorado Jeeper #10
Made famous by:
http://jeepforum.com/forum/showthread.php?t=274006
Feel free to resurrect that thread at any time :)
DreamsOfMoab is offline   Reply With Quote
Old 09-10-2006, 08:50 PM   #14
89'XJ
What would be a good chevy tranny to look for. I've heard good things about the TH-350 but I also heard it kills power.
Zack Miller
Old 09-10-2006, 08:54 PM   #15
Cerealdaemon
1988 FSJ Wagoneer
if you have to lift the engine some 3 inches for clearance, you might look into getting a cowl induction hood for your xj and chopping material out of the underside. The stock hood may or may not allor for proper clearance, I don't know, but a cowl hood certainly would
Glock Forum
