Chevy 350 in an 89 XJ - JeepForum.com
post #1 of 7 Old 02-05-2007, 02:50 PM Thread Starter
GreenDean
GreenDean's Avatar
I have a crappy little no option 1989 XJ just begging to be modified.
I have a free chevy 350, trans and transfer case from an 85 blazer.
Cost me no more than 500 buck to do it install.
(not including the required suspension lift).
Should I do it?
Anyone have pictures of a 350 crammed in the XJ engine compartment?
EDIT!
Heres a pic of the little bugger.
GreenDean is offline
post #2 of 7 Old 02-05-2007, 03:02 PM
TheNerd
TheNerd's Avatar
No pic for you, but a buddy of mine put a 350 in his Cherokee. Said he could smoke all 4 tires from a stand-still. He also said his biggest problem was getting a custom exhaust built (that and all the hoop-jumping to get the thing CA. smogged).
HELL YES you should do it!
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
post #3 of 7 Old 02-05-2007, 03:11 PM Thread Starter
GreenDean
GreenDean's Avatar
If i did the 350 conversion it would be a trail rig anyway. So that mean no emmision and a simple exhaust (dump tubes right out of the manifolds).
I have stupid question usually reserved for newbs here but... what lift would i need for 33's?
I know the answer for ZJs, YJs, and TJs, but not for the XJ.
4 inches should do it right?
post #4 of 7 Old 02-05-2007, 03:13 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Since it is a trail rig only, 3.5 to 4" would suffice with fender trimming. If you want more flex than clearance, 4.5" would be even better.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 7 Old 02-05-2007, 03:22 PM
Bendystraw11
To quickly answer you're question about the 350 swap, yes. Yes yes yes yes yes yes yes. Yes. As for fitting 33's, like Ultimate said, 3-4.5 will do with fender trimming, but if you don't want to trim much fender, go with the Rubicon Express 5.5"
'87 XJ: Trail Rig, '94 YJ: Totaled '61 CJ5, '65-'72 CJ5 (Still working on the year):Undecided; either for parts or a yard/light trail/ toolin' around Jeep, Late '50s Willys Pickup: FOR SALE! PM ME!
Now for the goods...The '87 XJ
Before: 6" Lift, 33"x12.50" Bridgestone A/T, stock 30 and 44, BA 10/5, NP231
After:6" lift, 17/40-15 Denman Ground Hawgs, MRW Beadlocks, HP D60 Front, D60 Rear, T-18, Dana 300
Bendystraw11 is offline
post #6 of 7 Old 02-05-2007, 03:30 PM Thread Starter
GreenDean
GreenDean's Avatar
i was thinking the 3.5 inch lift.
i want to do this on a budget and see how cheaply I can build this thing.
its going to be a complete beater.
If i feel like jumping it or braod siding a tree for the heck of it. i dont want to worry about the $1000 i just spent on parts.
post #7 of 7 Old 02-05-2007, 03:46 PM
RussoGuitar
1989 XJ Cherokee
3.5- 4 inches with a decent amount of trimming should fit 33's
RussoGuitar is offline
Chevy 205 behind AW4? Swampwalker3 XJ Cherokee Technical Forum 3 06-29-2009 09:59 PM
Chevy HEI in a 4.0???? vinceleonard XJ Cherokee Technical Forum 7 09-18-2007 07:47 PM
2.8L chevy Swap Grey4.0L XJ Cherokee Technical Forum 8 02-21-2007 09:55 PM
Chevy V8 into an XJ.. zeek XJ Cherokee Technical Forum 35 11-03-2005 03:37 PM
Chevy 350 Brian Peake XJ Cherokee Technical Forum 1 06-10-2002 12:44 AM
