Cherokee XJ Cowl/Hummer Snorkel Build / How - To - Page 2 - JeepForum.com
post #16 of 39 Old 06-25-2010, 04:20 PM
Muddeprived
Muddeprived's Avatar
Originally Posted by Curt41 View Post
This....As cool as it is, and as much as I like to go overboard with my Jeep, this is very true.
It does come in handy in the desert and dry areas where having the intake up that high brings in clean cool air instead of dusty air.....but most people in the states wheel on rocks, forrest, and mud.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #17 of 39 Old 06-25-2010, 06:06 PM
Bustedmp
1992 XJ Cherokee
Looks good, but the shop vac hose is not big enough. I used it on my last one, and when in deep water it caused enough restriction to cause water to get sucked in around the airbox lid. You would be much better off using 3" or larger. Water getting sucked by the lid/air filter seal isn't the only downfall of shopvac hose. At high revs it will cause your engine to backfire and cutout from the restriction. It's not that big of a deal if you rarely go full throttle, but it isn't ideal.
Hold my beer and watch this!!!
Bustedmp is offline
post #18 of 39 Old 06-25-2010, 06:18 PM
slimpartywagon
1989 XJ Cherokee
Originally Posted by Project1 View Post
Looks awesome man! Nice jeep ...
I have seen a few people do this, there is a tread about this kind of cowl ... I almost did that but used this bad boy:
It's an AEV Snorkel Pre-Filter Top AEV / Nth Degree 40306041AA - AEV Snorkel Pre-Filter Top for 07-10 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
It keeps the water out.
this is closer to what the inside of what a genuine HMMWV (Hummer) snorkel cap looks like... I also agree with others the intake hose needs to be about 4" DIA. that small hose is not going to supply enough air, also what are you using for an air filter?
slimpartywagon is offline
post #19 of 39 Old 06-25-2010, 06:32 PM
Muddeprived
FYI, McMaster-Carr has a variety of different hoses in many diameters. I used 3" diameter hose and it sucks well....literally lol. Four inches is overkill IMO cuz part of the factory intake is around 3" diameter anyways. Just make sure you watch the temperature ratings of the hoses cuz you don't want it to melt and deform.
post #20 of 39 Old 09-20-2010, 09:30 AM
96-XJ
1972 CJ5
old post i know, but hopefully il get a response...
Why didn't you put the intake on the driver's side? It seems to me that it'd be less tubing, less underhood clutter, less expensive, shorter tube feed = better intake colder air?
96-XJ is offline
post #21 of 39 Old 09-20-2010, 09:59 AM Thread Starter
Medic22
Unfortunately, The windshield wiper motor sits on that side of the cowl.
1993 Jeep YJ, 4.0
Firefighters Jeep Club Member
Medic22 is offline
post #22 of 39 Old 09-20-2010, 12:45 PM
Muddeprived
I wanted it on the driver's side but legal issues and what Medic said prevented that plan. I can't have anything blocking the inspection stickers and the wiper motor prevented any hose from fitting. The hood hinge was also in the way.
post #23 of 39 Old 09-20-2010, 09:06 PM
Kevin108
Originally Posted by cherokee33s1991 View Post
this looks awesome but i dont see the point? your moving the height of the intake like 6 inches
This is an excellent question which I believe is most easily answer with MS Paint and whatever side profile of an XJ Google finds first.
You are right that the intake height only changes slightly when sitting level.
But offroading is seldom done on level surfaces. Driving downhill, for instance.
So, where do you want your intake?
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #24 of 39 Old 09-20-2010, 09:14 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
i don't know why others did not do it. i have mine on my drivers side without issue. only used about 2' of tube as well, but my filter sits outside as well.
similar underhood setup as others, just some flexible hose adn a few couplers to make it all work. i did away with my stock airbox (well, never had one) and am just using the stock intake hose coupled to the flexible hose ran out through the cowl to a pod filter under the cover.
and it does not hamper vision at all, hardley even notice it is there actually, but makes a helluva sucking sound at start up
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #25 of 39 Old 09-20-2010, 09:22 PM
Muddeprived
You would get a ticket and probably not pass inspection here in PA. Can't block inspection stickers, which are on the window in that exact spot.
I also couldn't get 3" hose in that small area. I wish I could have though....
post #26 of 39 Old 09-20-2010, 09:28 PM
underpowered
well we don't have any sort of inspection at all here in KY.
and mine is 3" hose ran up there.
post #27 of 39 Old 09-20-2010, 10:01 PM
Muddeprived
Do you have any pictures of the under hood setup going through the firewall? If I could make this happen like yours then it would be sweet. I have inspection next month and could ask them to put the inspection stickers 6" higher than at the bottom. Hmm......
post #28 of 39 Old 09-20-2010, 10:40 PM
coalregionXJ
1989 XJ Cherokee
Right now I'm running a snorkel setup of 4 inch tubing running down the a pillar into the fender directly into the airbox.. at the top I've gpt a k@n pod filter. I'm thinking of puttinng my pod filter which. Is 3 inches talll and filtered on 3 sides. Why not put that right on top of the cowl with a waterproof pre filter?.. I can order one from rocky mountain for 20 bucks. Then I would have. All the benefits of a cold almost ram air intake and still be waterproof.... Hmmm time to redo my system..
89 XJ 4.o ax15
6.5 inches of lift
lockers front and rear
32's mastercraft courser mt's
homemade snorkel
"hold my beer and watch this
coalregionXJ is offline
post #29 of 39 Old 09-20-2010, 11:20 PM
XJcruiser
anyone check out the Spectre cold air intake for cherokees? It runs through the cowl and replaces the airbox with an inline filter.
XJcruiser is offline
post #30 of 39 Old 09-20-2010, 11:31 PM
Kevin108
I reused the factory air box when I did mine. That simplifies filter location as you use the original filter and just suck air from inside the cowl. I've got about $25 in mine. http://www.jeepforum.com/forum/f177/...ml#post8805654
Kevin108 is offline
cherokee , cowl , hummer , intake , snorkel
My attempt at a cowl snorkel. srmitchell XJ Cherokee Technical Forum 155 01-03-2014 01:34 PM
My Cowl Snorkel...w/ pics spikestrip XJ Cherokee Technical Forum 5 01-27-2010 01:42 PM
Who has the cowl snorkel mod? I have q's Paulio91184 XJ Cherokee Technical Forum 2 01-16-2009 11:19 PM
XJ cowl/hummer style snorkel BIGplansNOmoney XJ/MJ Cherokee Non-Technical Forum 9 09-13-2008 01:42 PM
custom cowl snorkel sjbond67 XJ Cherokee Technical Forum 17 11-21-2007 04:43 PM
