cherokee stock specs error - JeepForum.com
post #1 of 5 Old 04-05-2003, 09:28 AM Thread Starter
RedJeepXJ
There is an error in the cherokee stock specs, didn't know where to post it
the early cherokee's did not have a double carden front driveshaft, they had a GKN style driveshaft this one slides in and out of the black cylinder,
it would be great if a note was attached about the limited amount of lift these can take as a warning to others(makes a very pronounced thumping/clicking sound, had to spend $175 to get a custom front shaft
t-case connection
RedJeepXJ is offline
post #2 of 5 Old 04-05-2003, 11:54 AM
EricsXJ
The Post man
EricsXJ's Avatar
Thanks. I'll update the post to show that information. What does "GKN" stand for? And what years had this type shaft?
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #3 of 5 Old 04-05-2003, 12:53 PM
old_man
old_man's Avatar
Any XJ with the NP207 xfer case. I know it was the 4bangers up through 87 from experience. Don't know about the early V-6 2.8's.
Tom Houston
Loveland, Colorado
old_man is offline
post #4 of 5 Old 04-05-2003, 02:09 PM Thread Starter
RedJeepXJ
I think all of them till 87 had this type (with 207 t-case), becuase there is no driveshaft that is a direct swap, you have to have them cut to length, and take a yoke of of a 231
not sure why it's called a GKN (manufacturer maybe) also seen it called somthing like HS? High-speed-something
to show the diff. in length
post #5 of 5 Old 04-06-2003, 06:25 AM
EricsXJ
The Post man
EricsXJ's Avatar
Thanks, I updated the specs post.
Eric
My website -
EricsXJ is offline
discussion on "Cherokee stock specs" post EricsXJ XJ Cherokee Technical Forum 21 07-09-2013 01:33 AM
Stock Shock Specs (lifted specs too) 79bigmack XJ Cherokee Technical Forum 0 01-24-2007 11:58 AM
? on the cherokee stock specs page niko3257 XJ Cherokee Technical Forum 4 07-12-2006 02:43 PM
Cherokee stock specs EricsXJ XJ Cherokee Technical Forum 4 07-07-2005 11:02 PM
Cherokee stock specs XJae XJ Cherokee Technical Forum 3 01-28-2003 03:01 PM
