Cherokee is Misfiring and "hiccuping" - Page 2 - JeepForum.com
post #16 of 20 Old 05-04-2013, 04:47 PM Thread Starter
cavalier
So, if I do a compression test and get readings between 120 and 150, then do you guys reckon getting the head rebuilt without touching the block/pistons/rings, despite the high mileage?
cavalier is offline
post #17 of 20 Old 05-04-2013, 04:52 PM
79chiefs
1988 XJ Cherokee
Did you do dry, or wet compression test?
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #18 of 20 Old 05-04-2013, 05:00 PM Thread Starter
cavalier
Dry comp test, but I didn't pull all the plugs. Is that necessary? Or can I just pull one at a time?
cavalier is offline
post #19 of 20 Old 05-04-2013, 05:21 PM
79chiefs
1988 XJ Cherokee
Pull all plugs then do it so if pressure moves from one to another you have better readings, the wet test will tell you if you will have to touch anything other than the head.
95 E34 540i-DD
79chiefs is offline
post #20 of 20 Old 05-04-2013, 05:50 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Originally Posted by cavalier View Post
I'm not sure it needs to be that high. I think 31 psi is the spec.
You're correct. Fuel pressure spec varies with different years on the XJ.
For your 92, 31 psi is the spec at idle.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
