Cherokee is Misfiring and "hiccuping" - JeepForum.com
post #1 of 20 Old 05-03-2013, 04:52 PM Thread Starter
cavalier
It runs fine until it gets a little warm, then it starts misfiring. I can still drive it, it just "hiccups" every once in a while, especially while going up hills.
I recently changed the plugs, wires, cap, and rotor. I'm not sure what's going on. When I rev my engine and let off the gas, the revs drop too low and it almost starts to choke, but then it bumps back up.
Would a ****ty (airtex) fuel pump cause a misfire? Maybe a clogged injector? Maybe a sensor? HELP!
There's no check engine light. 1992 XJ with 228,000 on the 4.0.
cavalier is offline
post #2 of 20 Old 05-03-2013, 05:03 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Checking fuel pressure is easy. Fuel pressure gauges can be rented inexpensively from many parts stores. Testing is the only way to confirm a fuel delivery issue.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #3 of 20 Old 05-03-2013, 06:01 PM Thread Starter
cavalier
Hmm. Would a bad ignition coil cause a misfire?
cavalier is offline
post #4 of 20 Old 05-03-2013, 06:54 PM
79chiefs
1988 XJ Cherokee
Yes, test the spark.
It should be blue, and snapping spark.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #5 of 20 Old 05-04-2013, 09:17 AM Thread Starter
cavalier
So I just did a fuel pressure test. Here's what I got:
Key in "start" position: 36 psi but gradually goes down as I let it sit
Vehicle idling: 32 psi
Giving it gas: goes up for a second, then stays around 32 psi
Disconnect vacuum line to pressure regulator: goes up to about 42
Thoughts?
Now, I do notice that my exhaust is leaking at the manifold gasket. Bubbles of oil are popping in that area (spilled oil, that is). I'm wondering if an exhaust problem would cause a misfire (like a clogged cat). I haven't noticed any loss in power, just a misfire.
cavalier is offline
post #6 of 20 Old 05-04-2013, 09:47 AM Thread Starter
cavalier
OH MAN! I just pulled my plugs. THEY ARE FRIED! Check out this pic:
They are only 1 month old!
What's going on?
cavalier is offline
post #7 of 20 Old 05-04-2013, 10:54 AM
tjwalker
tjwalker's Avatar
Do all of your plugs look like that?
That looks like ash deposits. Excessive amounts can cause misfires.
*Have you been using any gas or oil additives? Additives can sometimes cause ash deposits.
*What type of oil are you using and how often are you changing it?
*Otherwise, it's an internal problem, possibly head related.
post #8 of 20 Old 05-04-2013, 10:56 AM Thread Starter
cavalier
Originally Posted by tjwalker View Post
Do all of your plugs look like that? How many miles on them?
At least two of them look like this. I'll pull the rest, but I think they do all look like that. About 800 miles on them.
cavalier is offline
post #9 of 20 Old 05-04-2013, 11:37 AM Thread Starter
cavalier
So I thought: maybe it's running rich? I pulled the coil and got 1.3 ohms for primary circuit and 12.47 Kohms for secondary. Seems fine to me...
cavalier is offline
post #10 of 20 Old 05-04-2013, 11:57 AM
79chiefs
1988 XJ Cherokee
Your fuel pressure is low, and how fast does it drop?
Sounds like bad regulator.
95 E34 540i-DD
79chiefs is offline
post #11 of 20 Old 05-04-2013, 12:01 PM Thread Starter
cavalier
It won't drop while I'm running it. At idle, it stays at 32 psi no matter how much gas I give it. Just when I first put the key to "start" and wait a while. It drops about a psi every 20 seconds.
cavalier is offline
post #12 of 20 Old 05-04-2013, 12:17 PM Thread Starter
cavalier
No additives. Cheapest 10w 30 I can find. Napa or Supertech. Change it about every 3k.
cavalier is offline
post #13 of 20 Old 05-04-2013, 02:14 PM Thread Starter
cavalier
Oh man. I'm starting to think maybe I need a head rebuild. NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!! !!!!!!!!!!!!!!!!!!
cavalier is offline
post #14 of 20 Old 05-04-2013, 03:15 PM
79chiefs
1988 XJ Cherokee
You also need a pressure regulator, it should be 49psi +/- 5psi all the time. But should NOT drop that quickly. 1psi/30min i believe is how it should drop when not running.
It does not drop while running because the fuel pump is always running, when it is not running and the key is on it only primes till your start it.
95 E34 540i-DD
79chiefs is offline
post #15 of 20 Old 05-04-2013, 03:43 PM Thread Starter
cavalier
I'm not sure it needs to be that high. I think 31 psi is the spec.
cavalier is offline
