Cherokee issues/occasionally starts - JeepForum.com
post #1 of 7 Old 01-03-2012, 09:35 AM Thread Starter
cvisinho
It is a 2000 cherokee 4.0, he is an older gentleman with minimal mechanical skills.
I scanned the computer and received 2 codes.
P0340 – which is the CPS
P0305 – cylinder 5 missfire
It will start 1 out of 7 days.
I tried starting it and sounded fine except it wouldn’t fire up.
I checked all connections looking for disconnected wires etc, all looks fine and the battery is currently on a charger to freshen it up, there is gas in it as well.
It has been sitting since Sept for the most part except the occasional start.
I am going to change the spark plugs for him and swap in a new CPS to see if that works.
Any help/suggestions are appreciated
cvisinho is offline
post #2 of 7 Old 01-03-2012, 10:14 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
P0340 is no cam signal at PCM.
My first thought is that this is a camshaft position sensor issue. However, it is still possible that the crank sensor is involved, but usually when the crank sensor is involved, it will set an additional code (along with the P0340) like a P0320.
I would look to the cam sensor first. They can be tested with a manual and a meter and I'd certainly test it.
Here are a couple of links on the P0340 that you should check out......
http://www.justanswer.com/jeep/33mij...-no-spark.html
http://www.obd-codes.com/p0340
Good luck and let us know how this is resolved!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 7 Old 01-03-2012, 10:34 AM
buildin1XJ
Trouble codes
Also go through all of your grounds and scrape any debris from them,pay special attention to the grounds down an the block next to the oil dipstick tube and ground that attaches from the back left corner of the block to the body, I'm not certain on the 2000 model where others are located since the newest jeep I own is a 1999 with distributor and you have coil packs and from my understanding your CPS is attached to the top of the oil pump drive. Remove onlu the CPS and not the OP drive. The CPS probably is the cause for #5 misfire. Also have a good strong battery that has good clean and tight connections. Hope this helps since all the true XJ gurus are probably at work right now.
buildin1XJ is offline
post #4 of 7 Old 01-03-2012, 10:37 AM
buildin1XJ
Listen to Tj
He is one of the better XJ gurus on this forum
post #5 of 7 Old 01-03-2012, 11:07 AM Thread Starter
cvisinho
Thanks guys, Ill keep you posted.
cvisinho is offline
post #6 of 7 Old 01-04-2012, 06:50 AM Thread Starter
cvisinho
changed plugs but battery was reading only 5V so i left it on the charger overnight.
CPS should be in tomorrow so ill swap that in when i put the battery back in.
cvisinho is offline
post #7 of 7 Old 01-09-2012, 08:15 AM Thread Starter
cvisinho
battery fully charged, new CPS installed = Still no start
Suggestions?
Not sure whats next. It might end up going to the shop as he is trying to sell it relatively soon and i can only get at it on the weekend for the most part
cvisinho is offline
RENIX 4.0 Idling low when warm, hard starts, occasionally stumbling GeologistFelix XJ Cherokee Technical Forum 20 08-26-2011 11:35 AM
86 2.8 v6 starts and dies, heat issues. Walshie XJ Cherokee Technical Forum 4 12-21-2009 09:13 AM
Cherokee country only starts sometimes dirkpitt XJ Cherokee Technical Forum 5 01-19-2006 11:38 AM
cherokee starts when it wants to - help... BigOrangeXJ XJ Cherokee Technical Forum 8 12-19-2005 05:30 PM
For all you 00 and 01 drivers who have issues with warm starts... BeachinXJ XJ Cherokee Technical Forum 2 11-23-2005 11:36 AM
