Quantcast Cherokee with HP30 and D44 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Cherokee with HP30 and D44
Old 10-27-2006, 08:25 AM   #1
Tj_Justin
Which years of the cherokee had the HP30 and the Dana 44 back axel. Im looking for a swap to put into my TJ.
Im going to lock them up with ARB and Regear them to 4.88s. Ill likeley rebuild them to im just going to look around a few junk yards to pick them up.
Might even put the jeep axels back in to make it a car that can make runs for parts and what not. But that may be a bad idea because i want the 4.0 so i can stroke her out and rebuild her to get those 4 chirping squirrels out from under my hood.
Tj_Justin is offline   Reply With Quote
Old 10-27-2006, 08:33 AM   #2
FitchVA
Jeeper 4 Life
FitchVA's Avatar
we've got a nice sticky up top with all of the stock specks...'
http://www.jeepforum.com/forum/f11/cherokee-stock-specs-26256/
Axles
Front Axles
Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 84-99 (some axles through 91 are vacuum disconnect, 92+ are non-disconnect, 89-95 with ABS have 5-297x u-joints, all 95+ have 5-297x u-joints, all others have 5-260x u-joints)
Dana 30 low pinion - standard cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear, 5-297x u-joints - used 00-01
Rear Axles
(Note on Dana 35 axles sometimes referred to as Dana 35C - The "C" does not stand for c-clip. It stands for "custom" meaning it came from Dana unfinished.)
(Note on 8.25 axles - none of these axles were used on XJs with ABS brakes. If you have ABS, you have the Dana 35. Without ABS you could have either axle. 8.25 axles are c-clip)
Dana 35 non c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 84-89
Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 90-01
Chrysler 8.25 - 27 spline, 1.17" diameter shafts, 8.25" ring gear, 3" axle tube - used 91-96
Chrysler 8.25 - 29 spline, 1.21" diameter shafts, 8.25" ring gear, 3" axle tube - used 97-01
Dana 44 non c-clip - 30 spline, 1.31" diameter shafts, 8.5" ring gear, 2.75" axle tube - used 87-89 on some(not all) XJs equipped with towing package.
'98 xj sport (trail toy) | specs
'98 xj classic (dd'er) | specs
'89 mj tinker toy | specs
My XJ Page | My Gallery
FitchVA is offline   Reply With Quote
Old 10-27-2006, 08:37 AM   #3
Tj_Justin
oh very sorry about that.... it been a while since i tripped and fell into the cherookee forum
Old 10-27-2006, 10:36 AM   #4
FitchVA
Jeeper 4 Life
FitchVA's Avatar
not a problem.
Old 10-27-2006, 10:45 AM   #5
bills79jeep
That wasn't a slight on XJ's was it?
1979 CJ-5 304 V8, 32x11.5 Kumho Mud Terrains, Edelbrock Intake, Carb, Cam
1998 Cherokee, 3.5" Lift, RE HnT SYE, needs installed, 31x10.5 Firestone Destination MT's, Herc'ed Interior.
http://www.cardomain.com/id/bills79jeep
bills79jeep is offline   Reply With Quote
Glock Forum
