Cherokee-front end wobble - JeepForum.com
post #1 of 6 Old 05-24-2005, 09:42 AM Thread Starter
themuskie
I have a 2001 Cherokee sport 4X4, 4.0. I get a really bad wobble in the front, ONLY when I hit 50-55 mph. The tires are new, theres new front shock's, stabilizer & I just put in new pads & rotors.(I do tow a 18' boat on a regular basis-figured I'd throw that in there.) What is that wobble...? I'm assuming its either the tie rods or ??
Thanks for any help-
Drive straight turn left...
themuskie is offline
post #2 of 6 Old 05-24-2005, 10:19 AM
sizzle-chest
sizzle-chest's Avatar
hey, i had the same problem with my 76 F250. from 45-50 mph i got a bad wobble thing going on, but i would break through it. I think it was because my tires werent balanced correctly. But other than that, i couldnt tell ye. I should mention that i had 35's on it without any lift, so that could have had something to do with it.
sizzle-chest is offline
post #3 of 6 Old 05-24-2005, 12:27 PM
CraigAllen
Like sizzle-chest said, it could be the tire balance... also possible that the steering stabilizer is worn out -- I replaced mine and it took care of that problem on my 86. The stabilizer cost me about $36 and was easy to replace.
96XJ Sport 4.0 Auto Chrys. 8.25, 1-3/4" BB. 242,776 miles and developing a bad rattle.
CraigAllen is offline
post #4 of 6 Old 05-24-2005, 10:08 PM
wolfepack215
wolfepack215's Avatar
1987 XJ Cherokee
The stabilizer will help solve the problem, but it is not neccessarily the entire solution, and will only mask another problem. Check alignment, tie rods, hubs, ball joints...... Whole front end inspection basically.......
Oh, and search the forum under "Death Wobble" ..... you'll see that 1. it happens alot & 2. There are lots of causes....
you may have just a slight wobble now, because if it were "Death Wobble" You would have posted something like.... "holy cr*p, front end felt like it was going to shake the steering wheel out of my hands". BTDT!!
wolfepack215 is offline
post #5 of 6 Old 05-25-2005, 08:04 AM
FRAYZ99
I also have a 2001 sport, stock, but i put new tires and Crager soft 8's on it . I had the worst wobble at 50mph on the nose, i was sure i balanced the tires, then I rebalanced and rebalanced. Finally after about 3 rebalances the wobble disappeared......Dont give up!
FRAYZ99 is offline
post #6 of 6 Old 05-25-2005, 09:21 AM Thread Starter
themuskie
Thanks guys. Aprreciate the info....I just got new tires on last night & it took care of the wobble...I still get a little, little bit when I brake down from 55-45...almost unnoticable...
Wobble in front, NOT death wobble, and yes I got the tires balanced 614XJ XJ Cherokee Technical Forum 10 09-26-2012 05:55 AM
Front end wobble Brew461 XJ Cherokee Technical Forum 5 09-09-2009 12:46 PM
Front end wobble - 2000 Cherokee kbaknife XJ Cherokee Technical Forum 2 08-10-2009 03:13 PM
Bad wobble up front 89'XJ XJ Cherokee Technical Forum 2 09-19-2006 08:19 PM
Front End Wobble STUCKINMUD XJ Cherokee Technical Forum 3 06-03-2004 04:29 PM
