Cherokee Classic 1999 making whining noise in back - JeepForum.com
post #1 of 6 Old 07-24-2009, 11:50 AM Thread Starter
Miro30
Hi there,
I have a 1999 Cherokee Classic, when I have drive at low speeds 10 - 40mph a low whining can be heard from the back of the car. When on the freeway it is less noticable. Do I need to change my differential. Any help would be great
Many thanks,
Miro
Miro30 is offline
post #2 of 6 Old 07-24-2009, 11:54 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would pull the cover and give the gears a look. Check the fluid for excessive metal particles, and if all looks good refill with new fluid and see if the sound is still present. It could be a bad bearing, low fluid, worn gears, it's hard to say without a visual examination.
xjfever is offline
post #3 of 6 Old 07-24-2009, 01:35 PM
jeeposaurus
jeeposaurus's Avatar
1990 XJ Cherokee
Originally Posted by Miro30 View Post
Hi there,
Many thanks,
Miro
Might be dumb to mention....but could it be the sound of your fuel pump? I know mine makes noise I can hear at idle (but then again I am without carpet in the jeep).
1990 Black 2 Door, Homemade 3" lift, 31x10.5 BFG AT's on rock crawlers, recovery front and rear, bed lined interior, rockerless, armored rear quarters, magnaflow muffler, CB, DIY Immobilizer, AC to OBA, Silverstars and a nice rack.
Build Up:
325,000km young.
jeeposaurus is offline
post #4 of 6 Old 07-24-2009, 02:31 PM Thread Starter
Miro30
Thanks guys, I don't think it's the fuel pump, when I'm idle, there is no noise, when I drive from 5 to 40 mph you can hear the noise. BTW, how much would a grear box run me.
Thanks
Miro30 is offline
post #5 of 6 Old 07-24-2009, 03:36 PM
ThaKingXJ
1997 XJ Cherokee
you have my problem!!!
ThaKingXJ is offline
post #6 of 6 Old 07-24-2009, 04:24 PM Thread Starter
Miro30
Hey ThaKingXJ,
How have you dealt with it? What have you found out?
Miro30 is offline
1999 Cherokee Classic Build vikingxj XJ/MJ Cherokee Non-Technical Forum 19 12-04-2008 12:54 AM
2001 Cherokee engine making whining/whistling sound titterton6529 XJ Cherokee Technical Forum 2 07-11-2008 03:53 PM
1999 cherokee classic Transaxle question jlbpa XJ Cherokee Technical Forum 3 12-28-2007 08:47 PM
16 inch wheels on 1999 Cherokee Classic hsv_photoguy XJ Cherokee Technical Forum 5 11-04-2004 09:18 PM
1999 Cherokee Classic vs. Sport... nfeldstrom XJ Cherokee Technical Forum 7 08-07-2002 05:54 PM
