Quantcast cherokee audio wiring problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > cherokee audio wiring problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 06-08-2006, 10:23 PM   #1
Cherokee98_4x4
i just put a cd player in my cherokee. the somewhere in the car theres a loose wire in my audio system. when ever i go over a bump my speakers in my car cut off but my system still is on since its connected directly to the cd player by RCA cables. any suggestions where i should start lookin.
Cherokee98_4x4 is offline   Reply With Quote
Old 06-09-2006, 12:17 AM   #2
mud-dog27
when i had that problem i ended up by-passing the whole harness connector and goin over every connection i could find and did it properly.....its time consuming but it worked
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit
My Jeep's Page
mud-dog27 is offline   Reply With Quote
Old 06-09-2006, 12:30 AM   #3
joejoejoe89
Is your CD skipping?
I got a 96 XJ with 2.5 liters running 4.10's out of the AX5 5spd pushin 31's out of a NP231 on the D30 front and C8.25 rear all underneath Rusty's 3-inches.
joejoejoe89 is offline   Reply With Quote
Old 06-09-2006, 12:39 AM   #4
Ghostjacker
are all of you speakers cutting out? usually the front speakers (one or both) will cut out.. since the wires in the doorhinge areas tend to snap
JEEP
Ghostjacker is offline   Reply With Quote
Old 06-09-2006, 02:03 PM   #5
pnpxtreme
Yea... it would be really unusal to have all the speakers cut out at the same time because of a bad connection.... but possible?
[SIZE="3"]For Sale![/SIZE]
[SIZE="4"]1996 Jeep Cherokee 2wd.[/SIZE] 160,000 Miles. Hitch, power sunroof, i-6 4.0 liter, black, very clean inside, third owner, 3inch rough country lift, 31" BFG's. Make offer
[SIZE="4"]2005 Yamaha Blaster[/SIZE]. Very good condition. Blue, 200 cc. Great first ATV! Make offer
[I]Will sell together or sperate.[/I]
[B]Email: Nate247628@aol with any questions![/B]
pnpxtreme is offline   Reply With Quote
Glock Forum
