cherokee 2" lift - JeepForum.com
post #1 of 4 Old 09-09-2011, 05:53 PM Thread Starter
tombo1787
cherokee 2" lift
hey guys im sure this is been done before, but here goes. If I do a 2" spacer lift, i know it isnt required to upgrade my shocks, however will i need to upgrade my steering stab. for any reason also what other problems may i run into? I am on a very tight budget.
tombo1787 is offline
post #2 of 4 Old 09-09-2011, 06:27 PM
Millermagic
2'' spacer in the front and Quadrated 1.5'' HD leaves in the rear ... couldn't be more impressed with it.
I tipped the jeep over a few minutes after that photo HAHA.
Front shocks are good for a 2'' spacer, I'm not running into any flex issues yet with the front shocks. Rear shocks seem to be doing okay.
Steering stabilizer you shouldn't need to upgrade unless you go with huge tires. And even then, if you start death wobbling, look into what is CAUSING the issue and not getting a bigger stabilizer.
The steering will be off center a bit because the drag link isn't long enough ... that's something easily fixable.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #3 of 4 Old 09-09-2011, 08:58 PM Thread Starter
tombo1787
awsome thanx for the advise and lookin good buddy
post #4 of 4 Old 09-10-2011, 10:54 AM
Millermagic
Thanks! Everyone said that a 215/85-16 tire would do horrible but it's unstoppable.
Didn't lose any driveability either. 2'' lift doesn't eat u joints.
lift kit , shocks , steering stabilizer
Going to buy my rims for 32" tires...is this right for a cherokee with a 3" lift???? kbadeaux XJ Cherokee Technical Forum 0 01-20-2011 03:40 PM
4" to 4.5" Cherokee lift questions rfrizzsqrd XJ Cherokee Technical Forum 9 01-17-2011 04:30 AM
jeep cherokee "budget" lift cconne20 XJ Cherokee Technical Forum 5 11-23-2009 09:16 PM
99" Cherokee w/ 2.5" lift ,steering problems, Help requested!!! soulman2010 XJ Cherokee Technical Forum 2 09-04-2007 10:32 AM
8" Lift on a 2WD Cherokee?? Littleg182 XJ Cherokee Technical Forum 12 03-14-2006 07:52 PM
