Quantcast Check out my "altercation" - ZJ brushguard on XJ - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Check out my "altercation" - ZJ brushguard on XJ
Old 03-09-2009, 03:35 AM   #16
ChewyXJ
nom nom nom
ChewyXJ's Avatar
Originally Posted by FrankZ View Post
You are calling me an idiot. What a tard......
Apparently he thinks that is a strong mounting system. I'd compare it to bolting a 2x4 to a piece of drywall.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline   Reply With Quote
Old 03-09-2009, 04:01 AM   #17
Muddeprived
Originally Posted by BunnyHunterOG View Post
I was hoping someone would catch onto the "altercation" thing.
As far as for the trail.
I used 1/4 inch thick angle iron. The size they are, theres no way theyre bending so I think you should be ok.
Its on there pretty good, its not going anywhere.
Im going to eventually extend two l brackets through the bumper to make it a little more secure, but the way it is, id feel comfortable side swiping a car. its not going anywhere.
The angle iron is pretty thick and strong, surprisingly easy to drill though with a good bit and fairly simple to hacksaw through.
It looks more like 1/8" thick than 1/4" thick. Could be the picture fooling me. What looks will happen is the bottom section of that angled steel attached to the front crossmember will bend backwards if the brush guard happens to hit a somewhat thick brush or tree. I don't see it doing too much damage to the crossmember unless it's bent back more than it can handle. What he needs is a horizontal mount, not vertical. With a horizontal mount, the force goes through the bracket into the frame. With the vertical, the force is all in the bracket and it'll bend easily. Alot of brush guards bolt to the factory bumper which uses "horizontal mounts", attached to the frame direction, not to a vertical bracket hanging below the frame.
Maybe fabbing additional mounts further up, like he mentioned, will strengthen it a bit more. You could get one on the top portion of the bumper. It'll be better mounting point than the one below. Not the best but better than how it is currently.
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote
Old 03-09-2009, 06:43 AM   #18
MuckShifter
This is my effort, without knowing where the stock guards mounted, I figured the recovery points, were as good a place as any?
MuckShifter is offline   Reply With Quote
Old 03-09-2009, 07:02 AM   #19
MuckShifter
It's not the strength of the angle iron, it's what you bolted to....Please, just stop.
I'm with you on this one
Mine's more of a sturdy light bar than a brushguard
Old 03-09-2009, 07:32 AM   #20
chainerx
1997 XJ Cherokee
I've never seen a brush guard hold up to any kind of collision with a solid object without crumpling. I was trying to point out that you can build the best damn mounting bracket ever and bolt a 2x4 to it, and it will still get broken.
If you think he's going to be playing bumpercars and just slam stuff out of the way with a brush guard, it won't matter how well you mount it. It's just not meant to hit stuff hard, it is made, as the name implys, for brush. Brush is only "a dense growth of bushes, shrubs, etc.; scrub; thicket." not trees, rocks, deer and cars.
1997 Jeep Cherokee
chainerx is offline   Reply With Quote
Old 03-09-2009, 11:13 AM   #21
Lynch_6913
so you just have that tinng bolted to 2 pieces of angle iorn? and the angle iorn is only bolted to fart of the frame that is like 1/8 thick at tops? hope ya dont hit nuttin or you'll be bent up bad... but good luck with that
2001 Jeep XJ 60th Year Anniversary Edition 2" Lift(Rough Country) Stock Tires
I am not an English Major nor do I care to be one.
The fact that I misspelled something doesn't/shouldn't affect the point I am trying to get across
LYNCH
Lynch_6913 is offline   Reply With Quote
Old 03-09-2009, 11:30 AM   #22
justanotherjpr
Anything thicker than brush will probably mess up the OP's mount, but it doesn't look like it was intended for anything else other than that. It doesn't look like the OP does much hard core wheeling, given that his Jeep is stock, so he probably won't notice the loss of ground clearance. Still looks better that the full size chevy setup...
justanotherjpr is offline   Reply With Quote
Old 03-09-2009, 12:36 PM   #23
MuckShifter
Hmm! "Say no more"
Old 03-09-2009, 01:10 PM   #24
Lynch_6913
well let me say if i was as obnoxious as you were on my bumper post i'd be sittin here for a while, all i'm gonna say is that while it looks good it probably wont stay on very long at all less your jsut mall crawlin then your in good shape... and sideswipein a car would most certianly turn that thing into a frisbee... but jsut keep us posted on how it works for ya!
LYNCH
Old 03-09-2009, 01:19 PM   #25
MuckShifter
Well put that man...pot calling kettle, I'd say?
Old 03-09-2009, 01:29 PM   #26
WhiteOut
WhiteOut's Avatar
If you do hit something, the guard WILL crumple back a ton. It is designed to bolt into the tow hook mounting locations on the ZJ, which are much stronger that this system. FrankZ is right that mounting this as is is kind flaky.
OP, you said this will hold up well against a car? It will not! I have seen these mounted correctly on ZJ's that hit a car or a stationary object and they bend. Sideswiping a car will probably rip the "mounts" off and it will most likely end up on the road.
WhiteOut is offline   Reply With Quote
Old 06-12-2009, 07:27 PM   #27
YJSXJ
1993 XJ Cherokee
its bolted to the car you idiot.
look at the pictures.
I highly doubt you're read of any of FrankZ's articles or seen any of his builds. But in this case, just give an apology where one is due and bite the bullet. On TOP of bolting to the sheetmetal of a unibody, those brushguards aren't that thick in material at all. Not in the tubing anyway.
Dont be so stubborn to take criticism. You put it here for the world to see.
later.
WTB WHEELS. .......Ecco's OR TJ Canyons. Send PM with what you have
Bruiser -- 93 XJ Sport. 9.5" of lift on 35"" Claws, Locked front & Rear, and some other crap.
Cruiser -- 1998 XJ Classic. 3" RC lift. 32" Kuhmo Ventures.
Originally Posted by bldeagle10 View Post
not really jeep related but my 14 year old cousin just pushed his man boobs together and said "doesnt that look familiar? ive got cleavage!!!"
wow. now hes jiggling his fat
Originally Posted by Hussler View Post
Since when does owning a jeep have anything to do with common sense???
YJSXJ is offline   Reply With Quote
Old 06-12-2009, 07:43 PM   #28
mspies1
I don't love it, but nicer than stock
For $50, can't beat it
mspies1 is offline   Reply With Quote
Old 06-12-2009, 07:55 PM   #29
LilRedDakota
Think OP will post pics after he hits somethin'?
Will be waiting.
P.S. MuckShifter, love the color
LilRedDakota is offline   Reply With Quote
Old 06-12-2009, 11:19 PM   #30
ajxj9197
1997 XJ Cherokee
i have a simlilar if not same brush guard and it seems to hold up fine..i have hit plenty of stuff with it so idk i mean if youre talking like a full on crash no, or ramming straight into a tree no..but i mean if beating on it plenty. By no means is it practical though its soley cosmetic im just saying it isnt as weak as it would seem.
The wise man sees in the misfortune of others what he should avoid.
ajxj9197 is offline   Reply With Quote
Glock Forum
