Check Gauges light....Battery indicator at 19.....HELP.. - Page 2 - JeepForum.com
 1Likes
post #16 of 25 Old 10-01-2013, 01:25 PM
cbourdon
Same issue, short trip to town, everything worked as normal. Stopped for (5) minutes, Jeep would not start. Weak interior lights and (1) click from the starter. Jump started, dash voltage meter pegged and ck gauge light on. Approx a mile down the road, meter came back to normal, ck gauge went out. Got home and let it idle for an hour, for what I thought, to recharge the battery. Again, (1) click from the starter. Long story to a short question, can the alternator go bad that fast ? Grounds and terminal connections solid, mildly dirty ... boom to bust after (5) minutes in the parking lot.
cbourdon is offline
post #17 of 25 Old 11-15-2014, 06:58 AM
moranparamus73
hello all I have a 1998 grand Cherokee this morning I was on my way to work my gauge lite came on my alt gauge was at 9on dash then was pinned to zero with my truck running anyone no what mite be the prob
moranparamus73 is offline
post #18 of 25 Old 11-15-2014, 07:35 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Test your way to the source of the problem, alternator/wires/wire connections/battery.
If the dashboard battery gauge shows 9 volts, most likely there is an alternator issue. If the dashboard gauge shows 19 volts, most likely there is a battery terminal connection issue, or a wiring issue.
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds.
CJ7-Tim is offline
post #19 of 25 Old 03-14-2015, 03:03 PM
tjgaddy
regarding spiking meter
Originally Posted by cgutta View Post
I have a 2001 Jeep cherokee limited 4.0 straight 6.....It has 108,000 miles on it....I have had it for 2 months....recently the check gauges light came on and the battery indicator was pinned at 19......It was on for about 6 miles or so then went off....back to about 14 volts wich is normal, then it went back on again for a few miles....I shut the truck off clicked the key over without starting it and it read at normal voltage...started it up and for the past few days no light and it reads at normal voltage with no problems.....YET...So what I am wondering is, could it be the alternator and is the voltage regulator in the alternator or could it be the ECM, or PCM....I guess i could replace the aternator with a new one and eliminate the alternator concern...if its the ECM or PCM how pricy is that? let me know you thoughts if you have any....Thank you.
I have had the same issue, turns out under the connector on the fire wall side of the fuse box that sits in front of the battery is a 10mmm nut holding down several wires and commonly these wires corrode and give you a meter spike and eventually the new battery and alternator will fail again, seemingly but it may just be the simple connection needing to be cleaned (sanding cloth or paper or wire brush)
tjgaddy is offline
post #20 of 25 Old 03-10-2016, 06:10 PM
SpecialK2000
same issue here.
I am having the same issue. spikes to 19v, then I turn it off, and it's dead. I brought my alternator to a very trusted shop and had it rebuilt. Popped it in and still same exact problem. I had already checked most of the connections, ground connections etc. but the problem just keeps getting worse as I check more wires. (I started with a P0135 1/1 oxygen sensor heater malfunction, now I'm into this problem and still haven't fixed the O2 sensor issue. I checked the fuses, wires, even each O2 sensor. I determined that power wasn't getting to the O2 sensor. I'm hoping this is just all related and am planning on just going to buy a new battery.) I feel like I'm walking into the woods and I can't find my way out. However, I've been able to fix every other problem I've had with this jeep so I'm confident I will get this one.
SpecialK2000 is offline
post #21 of 25 Old 03-11-2016, 08:57 AM
Millermagic
Have you done anything with the battery?
The last two times this has happened to me, it was a shorted battery.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #22 of 25 Old 11-02-2016, 07:48 AM
BluTeejay
Hi, I'm having the same problem on my 99 tj 4.0.
While the dash gauge is pegged out at 19v, I have a manual volt meter at my battery and it still reads 14.3v. No problems starting, battery holds at above 12volts when sitting over night. Did you find the problem?
BluTeejay is offline
post #23 of 25 Old 11-03-2016, 05:01 AM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by BluTeejay View Post
Hi, I'm having the same problem on my 99 tj 4.0. ...... the dash gauge is pegged out at 19v, ..... Did you find the problem?
See posting #18 above.
BluTeejay likes this.
CJ7-Tim is offline
post #24 of 25 Old 11-04-2016, 09:25 AM
BluTeejay
Came out of the gym yesterday and there was no power. After jiggling the negative battery cable, power came back. Replaced it. Thanks for the reply
post #25 of 25 Old 12-14-2016, 01:13 PM
mthibault
My 1997 Jeep Wrangler same problem. I hadn't started it for a week. I had the battery and alternator replaced four months ago. It wouldn't start and almost didn't start with the jump. I made an appointment to have what I thought was going to be a new starter in my future but decided to clean the terminals just to make sure as my negative lead was pretty gross.
Right after cleaning them my Jeep started right up! Time to cancel my appointment!
mthibault is offline
19 volts , 9 volts , alternator , battery , check guages light
Battery Gauge Drop. Check Gauges. dkongkill XJ Cherokee Technical Forum 12 05-17-2016 10:27 PM
Battery Gauge and check gauges light.. once again gallaghergoff XJ Cherokee Technical Forum 10 04-16-2015 05:34 PM
Can Check Gauges Light be caused by weak battery? kchilaka XJ Cherokee Technical Forum 3 04-22-2007 09:16 PM
Check Gauges and check battery light - 97 Jeep Grand Cheerokee Laredo darkstarpa XJ Cherokee Technical Forum 2 09-17-2006 06:24 PM
Airbag Light, Check Engine light, Gauges go dead.... OhioSpyderman XJ Cherokee Technical Forum 11 09-14-2005 09:50 AM
