Check Gauges and check battery light - 97 Jeep Grand Cheerokee Laredo - JeepForum.com
post #1 of 3 Old 09-17-2006, 06:17 PM Thread Starter
darkstarpa
here is my situation.
My check gauge light comes on after about 1-5 minutes of driving. The check battery indicator also pops up on the computer dash at the same time.
The batter voltage meter goes from 1/2 charged to zero at the point when the check gauges light comes on.
My Jeep starts up fine and drives okay with no power problems related to a battery issue it seems
Wondering if this may be a wire issue or something else.
Thanks for any input.
Darkstarpa
darkstarpa is offline
post #2 of 3 Old 09-17-2006, 06:22 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
How old is the battery? If it is not a sealed battery, check the fluid level.
If its not the battery, sounds like a loose wire on the voltmeter.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #3 of 3 Old 09-17-2006, 06:24 PM Thread Starter
darkstarpa
Thanks for your reply.
Check gauges light dert XJ Cherokee Technical Forum 5 10-12-2009 05:44 AM
When does the check gauges light come on? Dannyboy18 XJ Cherokee Technical Forum 2 03-02-2009 01:11 PM
Check gauges light VABarrister XJ Cherokee Technical Forum 2 01-25-2008 01:09 PM
Can Check Gauges Light be caused by weak battery? kchilaka XJ Cherokee Technical Forum 3 04-22-2007 09:16 PM
check gauges light? driverdriver XJ Cherokee Technical Forum 8 07-27-2004 02:55 PM
