Check engine light and "No Bus" on tripometer - JeepForum.com
post #1 of 4 Old 06-16-2010, 12:53 PM Thread Starter
Mikej1224
I had been driving for about 5 minutes yesterday, and then the check engine light came on, and on the tripometer it said "no Bus". after 10-15 seconds both the check engine light and "no Bus" message went away. i experienced no other problems with the car during or after that time. i was wondering if there is any thing i should be concerned about because of this. it is a 1999 XJ 4.0L. thank you.
Mikej1224 is offline
post #2 of 4 Old 06-16-2010, 01:20 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
This is a common issue on 97-01 Cherokees. It is a problem with the connections at the back of the instrument cluster. There is no other problems with the Jeep. It often goes away by itself, if not you can whack the top of the dash with your hand.
Here is the real fix, remove the cluster and clean the connections. The Wrangler is similar to the Cherokee - Fix your TJ's dead gauges (write-up) - JeepForum.com
CJ7-Tim is offline
post #3 of 4 Old 06-16-2010, 01:42 PM Thread Starter
Mikej1224
thanks Tim, that is most likely the issue. if it becomes a persistent problem, then i will take a look at the connections.
post #4 of 4 Old 06-16-2010, 01:54 PM
franknstn_cj5
search search search
franknstn_cj5 is offline
1999 Cherokee: I changed anti-freeze now "CHECK ENGINE" light is on...What happened? adreed24 XJ Cherokee Technical Forum 3 01-04-2010 05:03 AM
Check engine light: trans ecm not "talking" to engine ecm RockRodHooligan XJ Cherokee Technical Forum 1 12-19-2007 08:16 PM
What are associated "Check Engine Light" problems? dcdude XJ Cherokee Technical Forum 6 09-04-2004 01:07 PM
"check engine light" diagnostics mcardld XJ Cherokee Technical Forum 8 08-02-2004 09:13 PM
Help! "Check Engine" light is on due to T-Stat install (read story)!! Ghetto2315 XJ Cherokee Technical Forum 1 11-24-2002 01:21 AM
