Quantcast "check engine light" diagnostics - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > "check engine light" diagnostics
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 08-01-2004, 11:00 PM   #1
mcardld
I have a 2000 cherokee sport. The engine light just came on today. From the web, I found that the way to get the diagnostic codes was to turn on the ignition while holding the odometer reset button. I tried this, and as expected the gages and indicator lights started through their cycle and the O.D. cycled through all 1's, 2's..... 9's. However, after going through this cycle, there were no codes displayed (according to what I have read, I should have expected a code on the O.D. in the form of "Pxxx"). I tried this several times with the same result. No diagnostic codes. However, my "check engine" light is still on. Any ideas? Thanks in advance.
mcardld is offline   Reply With Quote
Old 08-01-2004, 11:04 PM   #2
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
You can go to Autozone and they will do a free reading for you. Or if the OD botton trick doesn't work, then do the key on off on off on. Don't start, just on off position. then a series of numbers and blinks will tell you your codes.
this link has all the codes
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Old 08-02-2004, 12:16 AM   #3
EricsXJ
The Post man
EricsXJ's Avatar
You cannot pull codes on a 2000 (or 2001...) by doing the ignition on-off trick that some of the older models can do. The test you did with the trip reset button is simply an instrument panel test. Bottom line is there is no way to pull the codes without a scanner. AutoZone will read the code for you for free, or the dealer will for a charge usually. Other than that you can purchase a scanner yourself >$100.
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 08-02-2004, 11:39 AM   #4
denverd0n
Eric is right. None of the ignition switch fiddling will give you the diagnostic codes on the last few model years of the XJ. Personally, I got one of these:
http://www.ghg.net/dharrison/obdscan.html
I think it was well worth the cost to be able to retrieve and reset codes myself, as well as monitor all the sensor inputs while driving if I want to. But Autozone and (I've heard) some NAPA places will retrieve the codes for you for free.
denverd0n is offline   Reply With Quote
Old 08-02-2004, 03:55 PM   #5
DougRuss
What about one of these, will this work ??
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2486005095&catego ry=43989
DougRuss is offline   Reply With Quote
Old 08-02-2004, 05:08 PM   #6
NissanHB41
1997 XJ Cherokee
I think 1997 was the last year to be able to check the codes yourself.
NissanHB41 is offline   Reply With Quote
Old 08-02-2004, 07:35 PM   #7
mcardld
Update- Thanks for the help. Per the advice above, I had it checked out at Autozone. The confirmed that the code is "P0455" which is a aparently a fairly common diagnostic for the EVAP/Vac/Gas Tank system. The most common cause for this is the gas cap, but after a quick visual inspection and several cranks (clicks) on the gas cap, everything appears to be O.K. Anyone else experience this before, or have any ideas as to the next place I can look? Again, thanks for the help.
Old 08-02-2004, 07:46 PM   #8
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
Did you disconnect the battery to reset the computer?
Matt
MY XJ PICS
Old 08-02-2004, 10:13 PM   #9
XJ Saga
It is your gas cap, I just went through this a few days ago. I had the mopar locking gas cap and it rusted through internally (dont know why) and failed to seal from then on causing a mil and same code you had. Replaced gas cap and problem solved.
XJ Saga is offline   Reply With Quote
Glock Forum
