Check Engine Light (CEL) code retrieval issue - JeepForum.com
post #1 of 8 Old 06-22-2010, 04:29 PM Thread Starter
JoSCh
1997 XJ Cherokee
I've used the forum a bit, but never had a question I couldn't answer with search... now I do.
I've got a 97 XJ that I've had and enjoyed for a few months. Now it is displaying the CEL and I've tried all the ways I could find here and on the intertubes to get the codes. Apparently the process changed in 97, so different things work for different builds. Naturally the one I buy is the transition... Turning the key on, off, on, off, on resulted in nothing. Doing it 4 "ons" resulted in nothing. Pressing the trip reset while turning the key to on 3 times resulted in the odometer displaying, in sequence, 111111, 222222, .... 888888, 999999 with various indicator lights and gauges doing different things at each count. Then nothing. The CEL remains on, it doesn't display any codes. I've let it sit like this for over 1 minute, but not too much longer. I've also tried the trip reset process with the "on" count at 4. Same result as the 3 "ons".
What is the next step?
I do have an Autozone nearby, I just wanted to do it this way if possible. Thanks in advance!
JoSCh is offline
post #2 of 8 Old 06-22-2010, 04:30 PM
DirtyViking
1995 XJ Cherokee
Easiest way is to just take it to Autozone if you can and have them yoink the codes out for free.
Originally Posted by Dcomf
As far as chicken coops go you'll only need 2 doors, if you had four then it would be a chicken sedan. :D
Originally Posted by Rob99
You can't post a thread in GD and expect only responses that you like. People have opinions. If you don't want to hear opinions, go have a conversation with yourself in the mirror.
After allegedly failing a sobriety test, Donald Duck was taken into custody.
Do evil every day. You may not change the world, but you'll have fun.
Halmotors on the PS3 network
DirtyViking is offline
post #3 of 8 Old 06-22-2010, 07:17 PM Thread Starter
JoSCh
1997 XJ Cherokee
Yeah, I like to do things myself if at all possible. Other than the Autozone solution, does anyone know what I'm not doing right? Why I'm seeing what I'm seeing?
JoSCh is offline
post #4 of 8 Old 06-22-2010, 09:34 PM
pentastar01
What you are seeing is the cluster test method. Just an easy way to determine that the cluster is functioning as is.
Life's tough, that's why I drive a Jeep. Until it breaks, then life's a *****.
pentastar01 is offline
post #5 of 8 Old 06-22-2010, 11:23 PM
JHamar
1997 XJ Cherokee
I have a 97 country. I have to do the hold trip reset and 4 ons and offs and it goes through everything then does a code. Some times it wouldn't work. But remember, the code you might get will probably be very generic. My NSS was messed up and the trip computer gave me a 45 code which could of been about 4 different things. Trip to autozone, asked them to check the codes for a check engine light and 2 min later I had pretty specific codes that people here can help with. I would try the hold trip in and do various combinations.
JHamar is offline
post #6 of 8 Old 06-23-2010, 05:12 AM Thread Starter
JoSCh
1997 XJ Cherokee
Thanks fellas, I didn't realize that the ODBII tester was more robust. I'll stop by Autozone tonite, and probably still mess with it to get the codes myself when I get home. If I find anything interesting I'll post it.
JoSCh is offline
post #7 of 8 Old 06-23-2010, 04:21 PM Thread Starter
JoSCh
1997 XJ Cherokee
Well, drove to work with the CEL on, when I came out the CEL is no longer on. It does flash when the key is turned on, so not a bulb or anything... I guess she fixed herself. Awesome.
JoSCh is offline
post #8 of 8 Old 06-23-2010, 05:50 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
As you mentioned, 97 was the "transition" year where early models could retrieve codes with the key-on, key-off method, but later builds in that year could not. Anything post 97 cannot use that technique.
As mentioned, best bet if you have a code is to get a code reader or a scan tool as the key-on key off method doesn't retrieve the entire 4 digit code that is necessary for best diagnosis.
Hopefully your light/code won't return. If it does, you know what to do. As the check engine light was on, you have "stored codes" to retrieve, regardless of whether the light is still on.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
1997 , cel , check engine light , cherokee , codes
Check engine light came on. Is there a way to check the code? mhall101 XJ Cherokee Technical Forum 11 01-08-2012 07:01 PM
Help with Check Engine Light Code kwalters XJ Cherokee Technical Forum 4 10-09-2007 01:16 PM
check engine light and code 12 mdoug445 XJ Cherokee Technical Forum 12 07-07-2004 11:30 PM
Check Engine light - how do I get the code? NevadaXJ XJ Cherokee Technical Forum 16 06-28-2004 02:12 AM
Check Engine Light - Code 51 tully_mars XJ Cherokee Technical Forum 3 05-15-2003 08:41 PM
