check engine light came on, what should i check? - JeepForum.com
post #1 of 22 Old 03-22-2008, 04:23 PM Thread Starter
99cherokeexj
just got back from the badlands and a day of fun, the only carnage is a fender flare. on the way home the light came on, what should i check out before something really goes wrong?
"99 red cherokee sport/ 1" spacer lift/ 31" BFG a.t.'s/ 2" spacers/ Front Tow Hooks/ recovery straps/ Hi-lift jack/ hitch/
lots of future mods
"99 red xj build
99cherokeexj is offline
post #2 of 22 Old 03-22-2008, 04:27 PM
xjcowboy01
It would be nice if something was sounding or acting funny. Keep an eye out for something like that because other wise youll have no idea unless you get one of those scanners to read the codes and find out what it is.
Live for those who have died for your freedom.
xjcowboy01 is offline
post #3 of 22 Old 03-22-2008, 04:28 PM
sprintagogo
This happened to me recently during an off-road trip. In my case the connector to the rear exhaust sensor had somehow come unplugged and was hanging down below the car, hence the CEL. This might be worth checking as branches or similar might have snagged the wiring underneath?
It took a few engine start/stop cycles before the light cleared.
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline
post #4 of 22 Old 03-22-2008, 04:32 PM
dudeinajp
dudeinajp's Avatar
gas cap
dudeinajp is offline
post #5 of 22 Old 03-22-2008, 04:37 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
If you have a check engine light, unless you stumble onto the problem, the best bet is to get the code read so you have some hard data to go on. Use the OBD2 technology on your 99.
Some of the big box parts store (Advance Auto Zone) will plug and read your codes for free in the hopes that you will buy necessary parts from them. Otherwise, any shop can do it and shouldn't charge you much for just reading them.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 22 Old 03-22-2008, 05:02 PM
SilverXJ
Check the codes?
SilverXJ is offline
post #7 of 22 Old 03-22-2008, 05:05 PM
AuburnXJ
1993 XJ Cherokee
Originally Posted by dude in an xj View Post
gas cap
x2 on the gas cap. Take it off then tighten it like 10 clicks. Then if the check engine light is still on about a day later just go somewhere and get the codes read
2001 Jeep Cherokee Limited - DD
4.5" Rusty's SA Kit-32x11.5 BFG AT-Super 44 w/ turndown-JKS Discos
1993 Jeep Cherokee - Trail Rig
6.5" Rusty's LA kit-33x12.5 TSL-Pacesetter Header w/Delta 40-JKS Discos-Tom Woods Driveshaft-Advanced Adapters SYE-Custom CAI
Coming This Summer: 44/9", 4 link rear, and 37s
AuburnXJ is offline
post #8 of 22 Old 03-22-2008, 05:21 PM
littleblackXj
1993 XJ Cherokee
littleblackXj is offline
post #9 of 22 Old 03-22-2008, 07:27 PM
SilverXJ
Originally Posted by littleblackXj View Post
That doesn't work on my 2000
SilverXJ is offline
post #10 of 22 Old 03-22-2008, 07:46 PM
1996xj
2005 WK
The CEL comes on because a sensor throws an odd reading or non at all. I have to laugh when ppl check all there fluids but cant figure out why the light is on.
But you prob wont be abke to figure it out unless you pull the code.
Why not just go to autozone or advanced auto and get your codes read for free
1996xj
3" Rough Country Lift, 3in shackles, 3 RC shocks, 31" BFG ATs, 2 KCs, Lighted Roofrack, Soft 8s, TC drop, Custom oil leak deflector.
If only i could get a set of tires to last me 10,000Miles
Originally Posted by toates89
i am just gunna drive around in 4lo on dry streets, and peel out
Originally Posted by 4.0H.O.XJ
I once got a ticket for jerking while driving it. The cop wouldnt let me use his pen to sign the ticket.
1996xj is offline
post #11 of 22 Old 03-22-2008, 08:54 PM
crateampscal
get a diagnostics done. 40 bucks
crateampscal is offline
post #12 of 22 Old 03-22-2008, 09:54 PM
itasor
itasor's Avatar
2009 JK Wrangler
Why would you pay $40 to get codes scanned? As mentioned a few times in this thread, most auto parts stores let you use their scanner for free.
itasor is offline
post #13 of 22 Old 03-22-2008, 10:47 PM
.45slinger
1995 XJ Cherokee
If you are going to keep the Jeep, or own more than one vehicle, why not just buy a code reader? You'll probably need it again sometime.
http://www.harborfreight.com/cpi/cta...emnumber=94169
95 Cherokee Sport 2 Dr
Posted via PCLinuxOS 2012
.45slinger is offline
post #14 of 22 Old 03-23-2008, 02:40 PM
AZ Jeff
2014 JK Wrangler
Go to the local AutoZone. They will attach an OBD-II scanner to the output port on the bus, and read any codes stored in the ECU that will have triggered the CEL.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #15 of 22 Old 03-23-2008, 06:22 PM
norsky
Agree, just go to local auto parts store and get it done for free, no need to pay.
norsky is offline
check engine light on 2000 cherokee.. can i check it my self? Magic2979 XJ Cherokee Technical Forum 27 12-11-2013 08:46 AM
Check engine light came on. Is there a way to check the code? mhall101 XJ Cherokee Technical Forum 11 01-08-2012 07:01 PM
check engine light/battery dummy light coming on iwishihad1 XJ Cherokee Technical Forum 4 08-23-2007 12:22 PM
Check Gauges and check battery light - 97 Jeep Grand Cheerokee Laredo darkstarpa XJ Cherokee Technical Forum 2 09-17-2006 06:24 PM
Airbag Light, Check Engine light, Gauges go dead.... OhioSpyderman XJ Cherokee Technical Forum 11 09-14-2005 09:50 AM
