Check engine light came on. Is there a way to check the code? - JeepForum.com
post #1 of 12 Old 05-22-2009, 07:33 PM Thread Starter
mhall101
while driving today my check engine light came on... is there a way to check the code or do i have to take it in and get some one to read it?
Originally Posted by 99xjjoe
"when i get in and turn the key the coolness goes through the roof"
mhall101 is offline
post #2 of 12 Old 05-22-2009, 07:36 PM
Ed Rico
1997 XJ Cherokee
You'll need to have the code read by an external OBD-II code reader.
-Ed Rico
Ed Rico is offline
post #3 of 12 Old 05-22-2009, 07:49 PM
98CherokeeLTD
1992 XJ Cherokee
go to advance auto or auto zone or a place like that. they will read the codes for ya for free. just bring a piece of paper and pen to write down the codes
Originally Posted by -XJguy- View Post
Damn pesky trees always jumping out into the middle of the road without looking.
98CherokeeLTD is offline
post #4 of 12 Old 05-22-2009, 08:32 PM Thread Starter
mhall101
thanks ill try that
mhall101 is offline
post #5 of 12 Old 05-22-2009, 08:32 PM Thread Starter
mhall101
is there a list of codes and causes on here?
mhall101 is offline
post #6 of 12 Old 05-22-2009, 08:40 PM
98CherokeeLTD
1992 XJ Cherokee
Here's a link to the error codes...(1998 and newer models)
Error code link
post #7 of 12 Old 05-22-2009, 08:42 PM
patrick02wj
i thought you could turn the key on and off a couple of times and it blinks a certin number of times or something like that?
2002 WJ I6, IRon Rock Offroad 4", JKs adj. trackbaR, Doetsch Tech 8000 Prerunner Shocks, 275/70/17 BFG AT, Black Moabs, tinted tails, Hellas
Alpine IVA-W205 Double din, JL Audio 10w7, Fosgate POWER 600/2, Fosgate POWER 400/4, FOCAL 165V30
patrick02wj is offline
post #8 of 12 Old 05-22-2009, 08:52 PM
the_weirdo
the_weirdo's Avatar
I think that works with OBD1 only.
the_weirdo is offline
post #9 of 12 Old 05-22-2009, 08:52 PM
patrick02wj
aaaah gotch
post #10 of 12 Old 05-22-2009, 09:29 PM
Ed Rico
1997 XJ Cherokee
http://www.obd-codes.com/
Ed Rico is offline
post #11 of 12 Old 05-23-2009, 08:20 AM
98CherokeeLTD
1992 XJ Cherokee
That's only the OBD1 system. The check engine light blinks. You turn the key on, off, on, off, on and watch the light. it will blink, and the blinks are separated by pauses.
Example- blink, blink short pause blink, blink, blink, blink long pause blink, short pause, blink, long pause blink, blink, blink, blink, blink, short pause blink, blink, blink, blink, blink.
codes would be
24 - TPS
11 - no crank signal to computer
55 - end of codes
post #12 of 12 Old 01-08-2012, 07:01 PM
Kasia
1994 XJ Cherokee
Mine's OBD1... I tried the 'on-off-on-off-on' technique but my light doesn't blink. is there something i'm not doing right?
it stays on- the 'shift' light (orange arrow) stays on as well. not sure if that makes a difference.
Kasia is offline
Help with Check Engine Light Code kwalters XJ Cherokee Technical Forum 4 10-09-2007 01:16 PM
check engine light... how do i get the code xj5399 XJ Cherokee Technical Forum 4 12-17-2006 07:38 PM
check engine light and code 12 mdoug445 XJ Cherokee Technical Forum 12 07-07-2004 11:30 PM
Check Engine light - how do I get the code? NevadaXJ XJ Cherokee Technical Forum 16 06-28-2004 02:12 AM
Check Engine Light - Code 51 tully_mars XJ Cherokee Technical Forum 3 05-15-2003 08:41 PM
