Quantcast check engine light '96 4.0 HO Country - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > check engine light '96 4.0 HO Country
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 03-01-2006, 08:27 PM   #1
4 wheel high
Hi guys,
My folks has a '96 Country 4.0 HO Auto w/108k. The check engine light comes on and stays on..never flickers on and off. It runs smooth on the road and at a stop sign. The only thing that is different is that when it gets warm (not even up to operating temp) it becomes hard to start, but will start fine when cold. I had an '88 XJ, but had to 'upgrade' in size to a Dodge GC due to the family. As you know, they did alot of computer changing from'88-'96, so I'm pretty much at a loss on this one. Could it be the o2 going bad? How about injector sensors? Any help would be really appreciated! TIA!!!
Craig
4 wheel high is offline   Reply With Quote
Old 03-01-2006, 08:30 PM   #2
dynamite44
Originally Posted by 4 wheel high
Hi guys,
Craig
double post homeboy. deliete one of these.
2000 XJ silverstone metallic.
[URL=http://www.capitaljeeps.com/jotm.shtml]i won jeep of the month on my local club page![/URL]
[URL=http://community.webshots.com/album/265206206KXtdOH]webshots off road pix[/URL]
[URL=http://members.cardomain.com/outofcontrol]Cardomain[/URL]
[URL=http://capitaljeeps.com/gallery/dynamite44sgallery]my capitaljeeps.com gallery[/URL]
dynamite44 is offline   Reply With Quote
Old 03-01-2006, 08:36 PM   #3
cjwalkeriii
I would be willing to bet that it's the coolant temp sensor on the T-Stat housing. I recently overheated mine resulting in damage. I put a snap on scanner on it, turns out it was reading to high. Regardless, if the temp sensor is inaccurate, in you case indicating that the engine is always cold, it will constantly try to start out as if it was cold similar to choked. Take it to advance and get them to pull the code, then come back and let us know. or go by the temp sensor and give it a shot. Just an idea...
jamie
remeber, this is the temp sensor for the ecu, not the gauge!
cjwalkeriii is offline   Reply With Quote
Old 03-01-2006, 09:52 PM   #4
AZ Jeff
Did you interrogate the check engine light by doing the key on/off trick to get it to flash codes?
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Old 03-01-2006, 11:03 PM   #5
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
If the key on-off doesn't work, take it to a autozone and have it hooked up to a OBDII scanner tool. That will let you know what is tripping.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 03-02-2006, 08:50 AM   #6
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Turn the key to the off position. It is right before on. Flick the key from off to on, off, on, off, on. The check engine light will begin flashing. Get ready to copy the number of flashes down. Do that a few times, they can be difficult to copy and interpret the first few times. When you've decided what the codes are, post them and we'll let you know what they mean and what possible fixes are. Good luck!
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Glock Forum
