Quantcast check engine light on 2000 cherokee.. can i check it my self? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > check engine light on 2000 cherokee.. can i check it my self?
Old 10-15-2005, 08:56 PM   #1
Magic2979
well i went and got my oil changed yesterday and i changed my air filter as well and i was driving all day yesterday with not check engine light.. didnt have it going to work. went out to get something to eat while i was still at work and the damn light came on.. Is there a way that i can check the codes myself on my 2000 cherokee or do i have to bring it some where?
My jeep runs and drives fine.. no iradic(sp) idle, starts right up. so im kind of confused.. i checked my gas cap and it on tight...
Also we have had alot of rain in my area.. roads flooding and everything. last night and this morning it was real bad could i of just gotten a sensor wet or something and it is triggering the code?
thanks for any help
Mike D
MY XJ Wheeling videos
[URL=http://videos.streetfire.net/Player.aspx?fileid=0E5262C3-7BEE-4C87-9D80-97C69B36E2B1]Me and F-150[/URL]
2000 Cherokee//3" lift 34s
1988 Cherokee- street xj project
Magic2979 is offline   Reply With Quote
Old 10-15-2005, 09:10 PM   #2
cjwalkeriii
I think you can go to advance and they will read them for free. After that, you need to find what's trippthe code. Sometime there easy, sometimes you have to follow a flow chart to fig it out. Also, someone may know, but i beleive you can turn the key on and off a few times, and the dash lights will blink the code. Best of luck
cjwalkeriii is offline   Reply With Quote
Old 10-15-2005, 09:34 PM   #3
djshortsleeve
Any auto parts place will read the code for you, IE VIP, Advance, Auto Zone. I had the good ole light come on last week and it came on cause I wasnt paying attention when I got gas and didnt click the cap back on. So you see it could be anything.
djshortsleeve is offline   Reply With Quote
Old 10-15-2005, 09:47 PM   #4
Ghetto2315
Since your XJ is running fine, what I would do is disconnect the negative terminal of your battery for 10-15 minutes to reset your PCM. That will turn off the MIL light.
If the MIL light comes back on, then you know you have a problem... if it doesnt, you're good to go
2001 TJ SAHARA - STONE WHITE - 4.0L - 5MT
Ghetto2315 is offline   Reply With Quote
Old 10-16-2005, 02:37 PM   #5
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
I don't think this works on the later models.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 10-16-2005, 08:31 PM   #6
Magic2979
anyone know where i can get a list of what the error codes are so that way i know is wrong wen i have the people at autozone pull the codes tomorrow..
Thanks
mike
Old 10-16-2005, 08:48 PM   #7
insane1
yes that does work on all xj's with the digital odometer, all you need to do is cycle the key 3 times and on the third keep on and the codes will flash where your milage is read.
His: 98 2 door xj, 4.0 H.O., aw4, np 231, flowmaster exhaust, 1 in thottle body spacer,
TNT Customs 6.5 y-link long arm
Tom Woods Super Duty tail shaft conversion
35x12.50x15 Pro Comp Xtreme Mud Terrains mounted on pro comp alloys
Hers: 2005 Rubicon Stock (for now)
insane1 is offline   Reply With Quote
Old 10-17-2005, 02:09 AM   #8
Mateo94XJ
Thanks
mike
http://www.allpar.com/fix/codes.html
They should be able to tell you what they are, on an OBDII setup they will scan the codes using a scantool and give you a printout on receipt paper. Should tell you what system is having trouble, but not necessarily what cuased it.
My money's on you didn't tighten your fuel cap - it happens.
'94 XJ Sport 2dr.
'86 MJ
'42 Willys MB
Mateo94XJ is offline   Reply With Quote
Old 10-17-2005, 09:25 AM   #9
Dean O
When they pull the codes they'll tell you what it is. I had this come up on mine a few months back. They told me it was the gas cap. I tighten it down as best I could, just as I have been doing for 2.5 years and still kept having the light come back on at least once a week. I even went so far as to buy a new gas cap, that didn't solve it so I put the old one back on. For some reason, when I switched back to my regular gas cap I haven't had the problem since. I just decided it must be a Jeep quirk
2000 4-dr Sport XJ- RED 3" lift, moabs and 31" MTs
'97 TJ Sport- BLACK-2" lift and 32"s
Dean O is offline   Reply With Quote
Old 10-17-2005, 09:37 AM   #10
Vertisce
If you have a 2000 model it will be the same as my 2001. You can do 2 things to get the code.
Turn the key on and off and back to on 5 times without starting the engine.
or...
Hold down the odometer reset button while you turn your key to the on position without starting the vehicle. This will make it run a diagnostic and it will come back with a 2 digit code for you.
If you wanna get the REAL code that tells you exactly whats wrong go to Checker or AutoZone and get them to read it for ya.
Disconnecting the battery for 15 mins is a waste. Wil Badger gave me a good pointer...since the PCM can only hold info for about 15 starts...just start your engine and turn it off about 16 times and see if it resets.
Vertisce is offline   Reply With Quote
Old 10-17-2005, 09:45 AM   #11
wipedawg
Or how bout not waste a bunch of freakin time and just go get the codes read for free? Disconnecting the battery doesn't do anything on OBDII and turning your key numerous times doesn't do anything either.
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline   Reply With Quote
Old 10-17-2005, 10:29 AM   #12
Vertisce
Wow...thats odd...so your saying that when I tried it and it worked...that it didnt really work?
Yeah whatever...so anyway...
Both those methods will essentially reset your computer but...if you have a problem it will more than likely come back right away or within a 50 miles or so. I know I have unplugged my battery and tried resetting my computer in many ways and it just keeps coming back because I have an issue with the damned thing that needs to be fixed.
Old 10-17-2005, 12:20 PM   #13
AZ Jeff
or...
This method will NOT WORK on a 2000 model year XJ.
AZ Jeff is offline   Reply With Quote
Old 10-17-2005, 01:12 PM   #14
Vertisce
Thats odd...worked fine on my buddies 2000 XJ.
Old 10-17-2005, 01:52 PM   #15
mylt1
its worked for me to. several times on a 2000 xj 2wd. its my towns police car and has worked every time but its three times not five. never tired the reset button and turn the key.
mylt1 is offline   Reply With Quote
Glock Forum
