Check Engine Light - 02 sensor voltage too high bank 1 sensor 2 - JeepForum.com
post #1 of 16 Old 07-13-2004, 09:16 PM Thread Starter
billbarr100
I went to autozone to have my code read. the computer came back with a code reading 02 sensor voltage too high bank 1 sensor 2. First off, is that the sensor after the cat or before it. I just replaced the one before it. Second, is high voltage lean or rich, and can i have the sensor tested? The new one is 75 bucks so i don't wanna do it unless i have to. Also, could a wiring problem be the culprit?
99 Cherokee Sport Black
np242 aw4 8.25
RE 3.5 Super flex with adjustable track bar
Rusty's Trailrated Crossmember with skid plate
Front and Rear tow hitches
245-75-16 mt/r on moab wheels from rubicon
billbarr100 is offline
post #2 of 16 Old 07-14-2004, 06:12 PM Thread Starter
billbarr100
nobody???????????????????????????????
np242 aw4 8.25
post #3 of 16 Old 07-14-2004, 06:31 PM
MSHarnett
Broke Bogger
MSHarnett's Avatar
Did you replace that sensor with a Bosch sensor. I did and had the same problem. I then bought the OEM sensor from 4wd.com for half the price and it worked/works fine.
Matt
MSHarnett is offline
post #4 of 16 Old 07-14-2004, 09:17 PM Thread Starter
billbarr100
this problem has existed before and after that sensor was replaced.
np242 aw4 8.25
post #5 of 16 Old 07-15-2004, 12:28 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
hmm, usually the Autozone sensor thingys will say wether the problem is upstream or downstream. I'd say your best bet is probably to replace the other sensor, its most likely due anyway. Also, check the fuse in the passenger kick panel. I once got the wires wet and it popped a fuse. Took me days to pinpiont the problem.
Matt
post #6 of 16 Old 06-01-2009, 09:17 AM
jayashjeep
bank 1 sensor 2 autozone told me that is one before the cat i replaced it still testing bad where is that fuse everyone is talking about.
If mud aint flying you aint trying
jayashjeep is offline
post #7 of 16 Old 06-01-2009, 09:58 AM
colt933
I think its the one after the cat (sensor 2), from cylinders 1-3 (bank 1).
2001 Jeep Cherokee Sport
Old Man Emu 3" lift coils and leafs w/AAL
Old Man Emu Nitro Chargers front and back
Discos
AA SYE with front drive shaft
Stock Aluminum 5-spoke 15" wheels
colt933 is offline
post #8 of 16 Old 09-01-2009, 04:15 AM
Hamid
2015 WK
On my OBDII scan tool I got bank 2 sensor 2, but my engine is 4.0L, SHOULD BE NO BANKS, would that be the sensor after the cat.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #9 of 16 Old 09-01-2009, 10:28 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
First, stop listening to the retards at AutoZone.
Second, you have Google, use it. Everything you need to know is at your finger tips.
Bank 1 Sensor 2 is the the sensor in the back, nearest the cat converter
CJ7-Tim is offline
post #10 of 16 Old 10-12-2009, 09:04 PM
Cal777
Bank 1 Sensor 2
Don't listen to CJ7-Timmy. He has a CJ 7. The retards at Autozone are two steps up on him. It the one right below the collector on if get error 141, past the cat on 131.
Heres what the retards at Autozone have to say:
http://contentinfo.autozone.com/znet...01.jpg/1.image
Cal777 is offline
post #11 of 16 Old 10-13-2009, 07:24 AM
cumminsjeep24
1997 XJ Cherokee
bank 1 sensor 2 is after the cat. think of it this way, each exhaust manifold is a bank. cherokees only have 1 manifold, so there is only bank 1. sensor 1 is before the cat, sensor 2 is after the cat. dont trust autozone guys. if you have a question, ask a mechanic.
97XJ 97TJ 11WK2
KCCO
cumminsjeep24 is offline
post #12 of 16 Old 10-13-2009, 07:51 AM
tangofox007
Originally Posted by Hamid View Post
On my OBDII scan tool I got bank 2 sensor 2, but my engine is 4.0L, SHOULD BE NO BANKS.
"No banks" isn't an option. It's either one bank or two banks. And some Jeep 4.0L engines (including 2000+ XJ's) do, indeed, have two banks.
tangofox007 is offline
post #13 of 16 Old 10-13-2009, 08:02 AM
tangofox007
2000/2001 models have two manifolds. Two banks, four sensors.
Obviously, you can't trust the internet, either!!!
post #14 of 16 Old 10-13-2009, 11:09 AM
CJ7-Tim
CJ7-Tim's Avatar
CJ7 Timmy has owned 5 Cherokees, and his Jeep club has 9 Cherokee members, so he might know a little bit about them.
The Autozone people are tards, the diagram in the link above proves that because it is for a V-6 and of course, the Inline 6 cylinder engine has been in Jeeps since the 1960's.
Some 2000 and 2001 4.0L XJ's have the CA emissions with pre-cats and 4 sensors and some have the standard two O2 sensors and one cat converter.
If you only have two O2 sensors, your OBD-II trouble codes will read Bank 1 Sensor 1 or Bank 1 Sensor 2. Sensor 1 is nearest the engine and Sensor 2 is nearest the cat converter. The last two O2 sensors I installed in an XJ were for that exact code.
CJ7-Tim is offline
post #15 of 16 Old 10-13-2009, 11:37 AM
TheNerd
TheNerd's Avatar
Man... talk about a FAIL for a first Post. FYI: CJ-Tim is, in fact, a genius.
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
Code P0138 high voltage code, Bank 1 sensor 2? crmaverick89 XJ Cherokee Technical Forum 21 08-07-2017 04:31 PM
high voltage 02 sensor/bad coolant sensor Jh24k XJ Cherokee Technical Forum 2 01-24-2010 10:09 AM
Check engine light caused by..bank 1 O2 sensor thats 2 month old Jeep_Runner_83 XJ Cherokee Technical Forum 2 11-12-2008 06:16 PM
Check engine light and 02 sensor LS1POWER XJ Cherokee Technical Forum 7 12-22-2004 11:00 AM
P0138 Oxygen sensor high voltage, bank 1 sensor 2 Back2Basics XJ Cherokee Technical Forum 3 08-03-2004 11:33 AM
