Cheap Walmart lights pics... - Page 4 - JeepForum.com
post #46 of 243 Old 01-02-2004, 02:07 PM
RUparrothead
RUparrothead's Avatar
1980 J-Series Truck
Originally Posted by XJ99
I guess I was in too big of a hurry to do that. How does it come off for future reference? Do you just undo the 2 little phillips screws on the bottom side of the rack on each side? Thanks!
no...what i did is open the doors, stand on the inside and look at the front of the luggage rack. at the very front, you see where the little black plastic "end" pieces are on either side of the rail (the one going front to back, not the actual slider). those have a little clip in there that hold them on. there is also a torx head screw if you look at it from the top...just loosen those up a bit, then pop the clip for the end pieces. once those are off, just slide the sliders forward and they come right out! took all of 3 or 4 minutes.
1980 j-10, 4 speed Grandpa's old jeep
14 mk, FD1' 5 speed
RUparrothead is offline
post #47 of 243 Old 01-02-2004, 02:21 PM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Yes now I see. As for the 4 bolts I was talking about the're actually torx. Thanks man.
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline
post #48 of 243 Old 01-02-2004, 02:35 PM
RUparrothead
1980 J-Series Truck
anytime
14 mk, FD1' 5 speed
post #49 of 243 Old 01-02-2004, 09:15 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Hey, I pulled of the panel where the factory fog light switch is, and there was a harness plug into a dummy plug right where the factory switch should be.. does that mean there is already wiring down there for the fogs? that would be cool if there is!
Anyway, just thought I would check..
Does anyone know?
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #50 of 243 Old 01-03-2004, 02:58 AM
EnderUSAF
I got mine today. I was gonna put them on while I was at work tonight..... but now seeing that I'm the only one working I won't be able to. So I guess I have a project waiting for me when I get off tommorow.
Combat Search and Rescue: If you go down, I'll come.
EnderUSAF is offline
post #51 of 243 Old 01-03-2004, 06:09 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Does anyone know?
I saw that too. I think xcmbike said he tapped into those wires for power. I don't remember you might want to PM xcmbike and ask him if he used those wires. I just pulled the harness off and dremmeled out the plastic so I could mount the switch.
XJ99 is offline
post #52 of 243 Old 01-03-2004, 09:45 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
ok like I said I sawk at graphics!!!!
But I found the fog lamp switch connector. I tried to draw it in paint. Here ya go!
BTW. is there anyway to save a PDF page to a JPG?
XJ99 is offline
post #53 of 243 Old 01-03-2004, 10:57 AM
ecrab3
ecrab3's Avatar
My advice is to go ahead and just run the wires into the engine compartment. YOu did all the hard work buy tucking and hiding the wire behind the interior, the easy stuff is connecting it. By using your own wire, you can ensure that the guage wire is heavy enough to run the power without worry of melting factory wiring.
Use the blank spot that yall found and just put a nice cool switch with a built in light and run your wiring in conveluted tubing in the engine comparment and at the same time, run you a few extra wires for future accessories. Its a little bit of a pain but in the end its the way to go. YOu never know when you might add a musical air horn or more lighst one day
And word on cheapo wal mart lights I have 4 of the KC knock offs on my roof rack and 2 on the front AJs bumper and they kick arse!
Eddie Crab3
'97 XJ
Nuttin Special
ecrab3 is offline
post #54 of 243 Old 01-03-2004, 11:14 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Ya that's what I did. I went with a 10 gauge wire from the Battery to the rear of the Jeep. Mainly I did it for a small amp, power inverter, extra 12-volt plug in the rear, but it's good to have a hot wire so any time you need power you know where to go. I went with a 60 amp Fuse at the battery just incase it shorts out. Everything running on that power wire is separately fused as well.
XJ99 is offline
post #55 of 243 Old 01-03-2004, 02:29 PM
bj-666
bj-666's Avatar
well i just finished mounting my lights 6 of em they look great and i think they look pro. i used real 14 guage wiring from west marine it is much better quality than anything that came with the kit and it is better than anything at home depot too it took me a while to re-wire every light but i feel better knowing that the wires will not light my jeep on fire. (always a plus)
lights during the day
lights at night
Switches inside
thru roof fitting
following the hood release cable through the firewall
beefed up wiring
[COLOR=red]
96 xj sport 4.0 HO non-abs
218,000 runnin strong as ever
6" full traction, Q78's, 8.8 ECTED locker,Rocky-Road rock rails, proto fab front bumper, ramsey 8.5e, HPd44 ARB front, OBA, Quick disconects
bj-666 is offline
post #56 of 243 Old 01-03-2004, 03:54 PM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Originally Posted by bj-666
well i just finished mounting my lights 6 of em they look great and i think they look pro. Now i don't want to change but how do i post pics on the board i want to put some up of my lights and wiring. thanx
You have to host them on a seperate server. Unless you are a paying member. Alot of people here use imagestation I hear it's free. I use picturetrail it costs 19.99 a year. Once you get them on the net just copy the address of the picture by using the insert image button.
XJ99 is offline
post #57 of 243 Old 01-04-2004, 02:56 PM
EnderUSAF
Here's some pics of my finished product... on the el cheapo lights......
post #58 of 243 Old 01-04-2004, 03:07 PM
Islandroaddie96
Islandroaddie96's Avatar
Very impressive guys. bj-666, I'm particularly impressed with your installation - looks very clean and I like the look of 6 lights. They fit perfectly. Where did you go after you went through the roof and how did you get the wires from the headliner down to the switches etc. . .?
1996 XJ Sport
4.0L I6 HO; AW4; NP242; D30/D35; 3" Homebrew BB; 31" x 10.5" BFG A/T
Six Harbor Freight Lights (el cheapo)
GREEN JEEP CLUB MEMBER #74
Islandroaddie96 is offline
post #59 of 243 Old 01-05-2004, 04:51 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Looks sweet man! snow ........ ..... .... .. .
XJ99 is offline
post #60 of 243 Old 01-05-2004, 05:02 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
lights at night
Switches inside
thru roof fitting
beefed up wiring
Also very sweet. This has got to be one of the cheapest mods that looks very cool.
XJ99 is offline
Walmart off road lights Jeeper4life XJ Cherokee Technical Forum 22 12-22-2010 09:14 PM
Walmart Baja Lights - What amp do they run? TwoOne XJ Cherokee Technical Forum 14 02-15-2007 06:07 PM
help wiring up walmart lights... XmuthJ XJ Cherokee Technical Forum 24 10-02-2006 04:19 PM
where to get walmart lights? Cody_00_XJ XJ Cherokee Technical Forum 33 10-01-2006 07:08 PM
yay for walmart lights drew and not u XJ Cherokee Technical Forum 9 08-29-2006 11:03 AM
