#1 | |
Cheap Lift!
I already have a rough country 3 in full leaf pack lift on my jeep and i was wondering if there was some inexpenive way of giving it another inch or two... i was thinking about bringing it to a friend of mine to strech out the springs but the im not sure what i would do about the back end
Any Ideas??? Thanks KenXJ
#2 |
Here is the latest re-cap of what we have found:
Suspension & Lift: 1. ZJ V8 Upcountry Coils = 1-1.5" lift 2. F-150/Bronco Coils ('79-ish) = 4-4.5" lift 3. S10 leaf packs (cut eyes off S10 main and bolt pack under XJ main) = 3-4" lift 4. JK shocks = slight mod to fit 2-4" lift 5. MJ Shackles = 1/2" lift 6. Camaro Spring Isolators = 1.5" lift Brakes: 1. WJ brake booster 2. WJ Master Cylinder 3. YJ Brake Lines = 3-4" longer 4. Dodge Ram Van Brake Lines = 10-12" longer (for big lifts) 5. WJ Rotors/Calipers = bigger brakes and more stopping power (will fit 15" rims) Axles: 1. Ford 8.8 inch ('97+) = need spring & shock mounts (4.10, LSD, Disc Brakes) 2. XJ I-4 & V6 = 4.10 gears (some have 4.56) may have vacuum discos 3. 97+ XJ C8.25 = bolt in and upgrades to 29 spline (strength comparable to D44) Front End & Steering: 1. ZJ V8 Tierods = beefier & bolt in 2. WJ Knuckles/Tierods/Draglinks = beefier and crossover steering 3. Durango Steering Box = beefier 4. 350 or 351 Power Steering Pump = helps with oversize tires (requires welding) 5. WJ LCA's = more tire clearance (some grinding required) 6. ZJ pitman arm = 1 inch drop over stock 7. WJ rear LCA's = replace XJ front LCA's, 2" longer to accomodate a lift, some grinding required Engine Performance: 1. Newer XJ intakes (may require some modification) 2. Mustang 5.0 Injectors = bolt in (have 4 holes instead of 1, more fuel, better spray) 3. ZJ V8 alternator = more power to run accessories (some grinding required) 4. Taurus Dual Electric Fans ('96-98) = replaces mechanical fan, better cooling Other: 1. '94+ V6 Dakota AX-15 = bolt in (but must use XJ bellhousing) 2. Lebaron or laser hood vents = help keep ur 4.0 cool 3. 97+ mirrors are direct bolt in to older XJ's and allow you to fold them in on tight trails. 4. MJ Bucket seats = tilt forward, bolt in to at least older XJ's 5. ZJ gas tank skid = can be modified to fit 97+ 6. ZJ and WJ stock tranny coolers with stacked plates (even an upgrade for us with the stock fin style) 7. GM power antennas replace your broken XJ's with little modification 8. 5spd crossmembers give 3/4 inch tcase drop on autos with no loss in ground clearance 9. You can convert the closed system to open without replacing your radiator by using the fill cap from a 4.7 durango or dakota, cutting it into your upper hose, and replace your bottle with an Mj overflow tank or any that fit. Then cap off or eliminate the T'ed lines in the heater core. 10. XJ '97+ doors onto older cherokees = one piece windows and better mirrors from a posting i stuck under favorites |
#3 |
shackles and spacers
The wise man sees in the misfortune of others what he should avoid.
#5 |
what do you mean by small block in the back ... i have a bad real main seal i leak oil sometimes i was talking to a friend of mine and they said if i go any higher than i am it will put to much stress on the seal and it will break also would i have to support the axles and put tie rods or anything because of adding an extra inch or two
#6 |
More than 3" and you start getting into more expensive territory (SYE, trackbar, etc).
But some spacers above the coils and some shackles in the rear will get you where you want. I wouldn't suggest stretching the coils out.
Jason '98 XJ: UpCountry, bastard pack, 2" spacers, JK shocks, 31" BFG AT's '81 Honda GL500 Colorado Jeep Club Member #399 |
#7 |
i wasnt planning on streching the coils ... but the shackles and the spacers wouldnt add any extra stree on the rear main seal would it ?
#8 |
Nope, it won't add stress to the rear main seal. If you are going to the trouble of lifting more, I would put 1.5 spacers in the front and 1.5 shackles (I wouldn't do a block in the rear) in the rear. You better make sure your shocks and break lines are long enough.
#9 |
forum supporter
At 4.5" or more you will need longer brakelines, you can use 95 wrangler brakelines from autozone or the like. You will also need an adjustable trac-bar and longer control arms. You will likely need a SYE/cv driveshaft for the rear too. Longer shocks and swaybar endlinks would be a good idea.
#10 |
XJfever if I were to do it the way you said do you any idea on where to get the shackles and or spacers offline and I wouldn't have to reinforce the stock axle or anything ?
#11 |
forum supporter
With your 3" kit did you get new lower control arms, and did you do anything to address the trac-bar?
#12 |
im not gonna act like i know what im talking about i got a rough country lift kit i dont think it came with anything for the trac bar and no new lower control arms
#13 |
forum supporter
If you still have the stock control arms and trac-bar they are pretty much at thier limits with 3" of lift. So you would NEED all the things suggested in post #9.
#14 |
I wish shackles didn't look so ghetto
they would def be the way to go
'01 XJ 2DR Sport GoJeep/Howto/BiXenonProjectors/XJ '99 WJ Laredo, 4.0L with HID Retrofit WJ HID Retrofit Pics |
#15 |
What year S10 for the leaf pack?
'98 Jeep XJ - DD - 3" lift.. 33x12.5x15r - Warn 8000 NEW PROJECT! '88 Jeep XJ - 5 Speed - 4.0L - Bone stock for now. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
