cheap air box mod ? - JeepForum.com
post #1 of 14 Old 07-25-2012, 11:41 AM Thread Starter
nick126
cheap air box mod ?
i am looking in to a intake for my 01 jeep cherokee sport but i dont wont to fork out 250 bucks for one and i plan on doing some muding with it. is there any thing i can do?
nick126 is offline
post #2 of 14 Old 07-25-2012, 01:26 PM
MeanGreenBean
1989 XJ Cherokee
I went and cut the front part of the intake (part that sticks into core support) off, plilugged the hole using great stuff and two portions of the cut off piece. Then i went and got a box elbow from true value cut a square in the back and put it back there with some silicone sealent around the edges. Ended up not aucking in water when i dipped into a water hole over my hood and that came up to my cherokee symbol when driving through. Definetly got my pants wet though
89 2dr XJ - D60/10.25 wlded F/R, 5.38 gears, Front leafs, 38.5x11 Boggers
MeanGreenBean is offline
post #3 of 14 Old 07-25-2012, 06:09 PM
MossGreen97
1997 XJ Cherokee
A lot of people replace their air boxes with cone filters to get more air flow. The problem is not the filter as much as the corrugated section between the air box and TB elbow. The corrugations disrupt air flow no matter what filter you use. To solve this issue on mine I dropped in a K&N panel filter combined with a piece of exhaust tubing 2 1/4 in. IIRC just long enough to go from inlet and outlet transition inside the tube. I sprayed some silicone spray on the tube and slid it inside the flex section. If you look at the inside of the hose you will see where the corrugation stops and becomes smooth on each end. This is where you want the pipe to stop. I measured this mod before and after with a digital air flow meter at work. I tested it at idle and there was a 6 cfm airflow increase. Air flow will increase at higher velocities as well because the turbulence would be greater at higher velocity without this mod. Total cost : about $47 for the filter and $5 for the pipe. And there is still enough flexibility to change the filter when needed.
'97 XJ Moss Green Metallic. 2DR. 2WD AW4 tow pkg.,3.73 gears. Firestone Destination A/T 225/75x15.
MossGreen97 is offline
post #4 of 14 Old 07-25-2012, 10:23 PM Thread Starter
nick126
mossgreen97 u wouldnt happin to have a picture of what u did? just so i can c what u did
nick126 is offline
post #5 of 14 Old 07-26-2012, 04:26 AM
MossGreen97
1997 XJ Cherokee
Nick,I'll take a picture and measurement this afternoon when I get home from work.
post #6 of 14 Old 07-26-2012, 08:32 AM Thread Starter
nick126
thanks
nick126 is offline
post #7 of 14 Old 07-26-2012, 10:32 AM
Kevin108
Cowl snorkel FTW! http://www.jeepforum.com/forum/f177/...ml#post8805654
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #8 of 14 Old 07-26-2012, 06:07 PM
MossGreen97
1997 XJ Cherokee
Here are the pics of my air tube mod. 2 1/2 in. OD exhaust tube 3 5/8 in. long inserted inside tube.
post #9 of 14 Old 07-26-2012, 09:59 PM Thread Starter
nick126
thanks for the pictures
nick126 is offline
post #10 of 14 Old 08-09-2012, 11:14 PM Thread Starter
nick126
i was wondering if i put the cowl snorkel in do u get at it from under the dash and if it gose in the cab will i take my heat away in the winter ?
nick126 is offline
post #11 of 14 Old 08-10-2012, 02:15 AM
Kevin108
No, you don't lose heat. The cowl is a big, open area and there's plenty of flow to feed both the engine and the HVAC blower. The snorkel doesn't come through the firewall. It ends under the windshield wipers.
Kevin108 is offline
post #12 of 14 Old 08-10-2012, 07:49 AM
Azzy
Another alternative is to use a 90 degree and 45 degree PVC fitting to just raise the intake up and back. That way you dont have all that sucking noise in the cab, but raise your ability to enter the water.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #13 of 14 Old 08-10-2012, 08:16 AM Thread Starter
nick126
ok thanks for i the info i give it a try and what did u use to cut the cowl ?
nick126 is offline
post #14 of 14 Old 08-10-2012, 11:02 AM
Planetcat
2010 WK
I used to have the rusty's tube on my 96. It was a clean, 15 minute install and worked great. Freed up a lot of room in the engine compartment.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
A cheap mod dlane2155 XJ/MJ Cherokee Non-Technical Forum 15 10-07-2010 07:41 PM
Why so cheap? NIN20 XJ/MJ Cherokee Non-Technical Forum 4 09-10-2008 10:49 AM
Where can I get a cheap, metal rear bumper? (for cheap) bigred54 XJ Cherokee Technical Forum 1 08-31-2008 03:50 PM
cheap 33's? eflores XJ Cherokee Technical Forum 48 03-02-2008 07:10 PM
Cheap CHEAP XJ lift Blk93Jeep XJ Cherokee Technical Forum 20 02-13-2006 01:57 AM
