| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Chasing down a misfire - coolant temp sensor?
#2 |
well if your temp goes up really quick ...you might need a cooling system flush. and maybe a new radiator. for future ref. operating temp for an xj is 195. so 210 is kind of hot, so you might need a new thermostat too, possibly water pump if its real old ...wow you really went through everything that i would have thought of for a misfire and then some. if it were me, id problably do a compression test next to see if the rings r toast. and testing to see if the exhaust and intake valves are good is a good idea as well. maybe you can get new fuel injectors before you do a compression test, i dont trust any of those BS fuel cleaners or anything like that.
#3 |
I forgot to add. Compression on cyl. 1 is 150psi. The others are 160 to 170. I will check out the thermostat, etc.
#4 | |
locked and loaded
210* is the normal operating temp indicated on the instrument panel gauge.
. For Sale - http://tinyurl.com/Tan-Overhead-Console . SUV's get groceries, Jeep's get dirty.
#5 |
i thought xjs were supposed to run at approx 195 give or take a couple degrees??
#6 |
forum supporter
They use a 195* thermostat, but operate at or around 210*
#7 |
i have a 180 thermo. and it operates at 180 . constantly
#8 |
Will do. Picked up some new orings incase I mess one up pulling the injectors out.
#9 |
I just swaped the #1 and #2 fuel injectors and it made no difference. I can pull the plug to the #1 injector and you can barely hear a difference in the way the engine runs. It makes a big difference if you pull the plugs to angy of the other injectors. I guess fuel pressure is next.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| will this fit? Coolant temp sensor | billabongopblue | Cherokee Technical Forum | 10 | 08-22-2009 10:22 AM |
| help.. coolant temp sensor | cobra | Cherokee Technical Forum | 2 | 01-24-2009 09:14 PM |
| TPS sensor, Coolant temp sensor, and 02 Sensor fail | kadetklapp | Cherokee Technical Forum | 2 | 09-07-2008 01:48 PM |
| coolant temp. sensor? | BigOrangeXJ | Cherokee Technical Forum | 3 | 08-10-2007 03:04 PM |
| where is my coolant temp sensor?? | ktmracer419 | Cherokee Technical Forum | 6 | 02-01-2006 11:37 AM |
The time now is 04:56 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
