charging problem - JeepForum.com
post #1 of 3 Old 06-26-2005, 10:32 AM Thread Starter
Havoc319
charging problem
New to this place. Very cool.
Just put in a new 160ah alternator. Originally had a 75 I think? It would drop out when everything was on.
The new one seams to do the same thing as the old one. It just cannot handle a load. Checked the grounds, getting an amp meter today to check and also I think there is a fusible link inline with the alternator to the starter relay??
Is there anyway to jump out the regulator to have it put out max power to see what it does? I was reading in my chiltons to jump out the regulator but it says for an external one.. Any help?
Dan
1990 XJ
www.teamsolorobotics.com/1990XJ.htm
Havoc319 is offline
post #2 of 3 Old 06-26-2005, 02:59 PM
XJ-NoDough
XJ-NoDough's Avatar
I used to have all kinds of electrical issues, then I discovered that my engine grounding strap wasn't tightened down. Now it's much better.
My DD
'89 XJ Limited
204,XXX miles
Leather, Loaded
4L Selec-trac
Automatic
3"-4.5"ish Homebrew lift
16x8 MB Motoring Rockers
265/75R16(31ish"X10.4") Goodyear Wrangler M/TRs
Trimmed w/ Bushwackers
Stock 3:55 gears
sans big audio
Homebrew intake w/cone filter
"Some people are like a slinky... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs." :my dad
XJ-NoDough is offline
post #3 of 3 Old 06-26-2005, 03:32 PM
wolfepack215
wolfepack215's Avatar
1987 XJ Cherokee
Check your ground, and Also::: Upgrage your Wire!!!!!!!!
If its the same wire that the old one was connected to. Current is flow of electrons...... wire is the pathway. If you want more flow, you have to increase the pathway. I saw it in a tech article once, but I cant remember where... Anyhow, I recently got a 4awg wire from my Alternator to the starter relay, and all my electrical systems work better. even my windows go up better now. All you need is an 18" jumper wire from your alt to starter relay. Thicker wire the better, and upgrade your ground, check for looseness and tighten if neccesary.
wolfepack215 is offline
charging problem? onebadjeep93 XJ Cherokee Technical Forum 3 11-23-2008 07:33 PM
Charging Problem Pacepaperboy XJ Cherokee Technical Forum 2 05-05-2008 03:08 PM
charging problem john1998 XJ Cherokee Technical Forum 1 02-09-2007 06:52 PM
charging problem deragheth XJ Cherokee Technical Forum 2 02-03-2007 08:26 AM
Help with a charging problem? tonyzog XJ Cherokee Technical Forum 3 09-29-2005 12:30 PM
