Changing power steering hoses 2000 XJ - JeepForum.com
post #1 of 8 Old 06-24-2013, 07:54 AM Thread Starter
JBlue
I decided to change both hoses on my power steering pump. I took out the air filter and electric fan but cannot really get to the bottom part of my hoses. It appears that a radiator hose is in the way. Has anyone done this before? Also, does anyone know what wrench to use? It was bigger than my 5/8. I went to the store and bought a 3/4 but it was too small for this. Is there a decent guide for all of this? I'm not impressed with the Haynes manual. Thanks.
JBlue is offline
post #2 of 8 Old 06-24-2013, 08:11 AM
CCKen
CCKen's Avatar
You'll need an 18 MM Crowfoot flare nut wrench, long extension, and a breaker bar, to remove and install the flare nuts at the steering gear.
CCKen is offline
post #3 of 8 Old 06-24-2013, 09:02 AM Thread Starter
JBlue
Thanks a lot. Is there a good place to pick up that sized nut wrench? Also, do I need a whole set or just that one size? I mean, in the future while working on an XJ, will I need the other sizes or the 18mm will do the job?
JBlue is offline
post #4 of 8 Old 06-24-2013, 09:23 AM Thread Starter
JBlue
Also do I need a breaker bar and an extension? Thanks for the help.
JBlue is offline
post #5 of 8 Old 06-24-2013, 09:40 AM
CCKen
CCKen's Avatar
There's not too many applications on your XJ for flare nut crowfoot wrenches so I would just see if you can buy just one wrench. I got mine at a local hardware store but you can check Sears or some of the automotive parts stores, like NAPA.
CCKen is offline
post #6 of 8 Old 06-24-2013, 09:43 AM
CCKen
CCKen's Avatar
That's what I used. It's too difficult to get down on the flare nuts without the extension, but you can use what you want to turn the crowfoot. I just happened to have a 3/8 drive breaker bar that I used.
CCKen is offline
post #7 of 8 Old 06-24-2013, 10:05 AM Thread Starter
JBlue
Thanks Ken. Autozone has a cheap set I'm going to pick up tonight.
JBlue is offline
post #8 of 8 Old 06-24-2013, 11:07 PM
Kevin108
I cut the old hard line and used a socket to remove then reinstalled with a short 18mm for the pressure hose. Didn't change the other one though.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
