changing fuel pump on 1992 cherokee? - JeepForum.com
post #1 of 8 Old 10-16-2007, 04:56 PM Thread Starter
323
i think my fuel pump went to ****. and a new one will be 100 bucks. i found a shop that will do it for 230.00. worth it to do it myself? is it hard? or just let the auto repair shop do it.
323 is offline
post #2 of 8 Old 10-16-2007, 05:16 PM
nate758
easy to do change you fuel filter too could probably di it in 2 hours or so max
nate758 is offline
post #3 of 8 Old 10-16-2007, 06:15 PM
tangofox007
Replacing the fuel pump is fairly easy. Expect your lock ring to be stuck; a little penetrating oil will be helpful. And getting the lock ring back on is a challenge with a new seal. But certainly not worth paying someone else.
However, if the old pump failed due to contamination in the tank, you really need to have the tank cleaned. If the tank is clean, I would just replace the pump. It would also be a good time to renew the hoses and filter.
tangofox007 is offline
post #4 of 8 Old 10-16-2007, 11:51 PM
96JXJ
Make sure the fuel pump is bad. I thought mine had went out until I connected jumper wires to it. Worked fine, turned out the CPS was bad. JIM.
96@6 & 92@3
96JXJ is offline
post #5 of 8 Old 10-17-2007, 06:26 PM
ScottT80
Other than a CPS, what else would cause problems like a fuel pump?
Just put a new CPS on mine and a new fuel pump... problem still there... currently won't start at all.
Did note that the fuel rail has no pressure... new fuel pump not any good?
ScottT80 is offline
post #6 of 8 Old 10-17-2007, 07:34 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Check the ASD relay and the fuel pump relays and make sure both work. Also check the ballast resister on the drv side fenderwell. It's a small ceraminc thing. Jumper it and see if that fixes it.
If you're gonna replace the pump or even just the sock pre filter.... IMO, drop the tank and put some tank cleaner through it. Dropping the tank is a little bit of a PITA, muh easier if you don't have a hitch on there. It's the best way to get the pump assembly out without bending anything. Also the best way to make sure the little numb on eth bottom of the prefilter seats in the holde ri the tank.
http://www.cardomain.com/ride/2406854/3
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #7 of 8 Old 07-31-2009, 09:01 PM
94HOCHEROKEE
1994 XJ Cherokee
my fuel pump went out and I checked for pressure which I had none. I first thought it was my pump because I was doing some maint. and I had to turn it on and off and the fuel pump didn't engage like it had been and now won't fire.....
Also, when my CPS went the pump would always engage and act like it might fire after repeated tries. I hoped maybe it was my TPS but the fact remains that my pump wasn't engaging.......
94HOCHEROKEE is offline
post #8 of 8 Old 09-27-2014, 10:05 AM
betty0901
what is the CPS? Do you have any pictures of the removal of the lock ring/washer?
betty0901 is offline
Where is the fuel pump relay on a 1992 jeep cherokee? Eburgwheeler XJ Cherokee Technical Forum 1 08-22-2009 07:41 PM
1992 4.0HO Fuel Tank/F. pump Neebie question smitkev2 XJ Cherokee Technical Forum 1 07-05-2009 06:22 PM
1992 jeep cherokee fuel pump fiddlin1 XJ Cherokee Technical Forum 1 04-09-2009 07:24 PM
Changing Fuel Pump SlimGoaty XJ Cherokee Technical Forum 2 03-27-2006 07:36 PM
Changing A Fuel Pump 89 4.0 Cherokee REPOXP777 XJ Cherokee Technical Forum 3 09-06-2005 05:11 PM
