changing diff fluid, quick questions - JeepForum.com
post #1 of 9 Old 06-22-2013, 06:15 PM Thread Starter
jbudz511
Hello all!
So I'm going to drain and refill my differentials within the next few days for the first time since I've owned the xj. My question is I see there is an additive that's needed if you have a LSD, my question is how would one know they have one...
Also I was looking to clean up and possibly repaint the the diff covers while I'm changing the fluid, should I cover up the open gears while the covers are drying or does it not matter.
Thanks guys
jbudz511 is offline
post #2 of 9 Old 06-22-2013, 07:06 PM
CamdogXIII
1997 XJ Cherokee
If you own the 2000 xj listed in your profile You don't have an LSD unless the previous owner did an axle swap or installed an aftermarket one. If you want to make sure, jack up the rear end to take both tires off the ground and spin the drive shaft by hand. if both tires turn equally then there is an LSD. My guess is that they won't ;-)
and I would cover the differentials while the covers are drying to stop dust and dirt from getting in there.
CamdogXIII is offline
post #3 of 9 Old 06-22-2013, 10:07 PM Thread Starter
jbudz511
Thanks man, I'm pretty sure this is stock l. Sounds simple enough to test tho
jbudz511 is offline
post #4 of 9 Old 06-23-2013, 02:48 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Limited Slip was optional for all years of XJ. My 2000 had one, it was listed on the build sheet.
With the diff cover open, ID the gear carrier, open or Limited Slip. If you have a Limited Slip you need to add the Friction Modifier additive. You can either buy it when you buy the gear oil and return it if not needed, or drive to the parts store on your fresh gear oil and then buy some. I would not drive for days or weeks without the additive, but a few dozen miles without it won't hurt anything.
Open Differential on the left, Limited Slip on the right:
CJ7-Tim is offline
post #5 of 9 Old 06-23-2013, 08:34 AM
biffgnar
biffgnar's Avatar
A lot of gear oil has LSD additive in it already. Doesn't hurt anything if you don't have the LSD and avoids having to add anything.
biffgnar is online now
post #6 of 9 Old 06-23-2013, 10:05 AM
CJ7-Tim
CJ7-Tim's Avatar
Some Jeep owners have posted that these fluids do not work as advertised, and they still have to add Friction Modifier. YMMV.
CJ7-Tim is offline
post #7 of 9 Old 06-23-2013, 05:52 PM
CamdogXIII
1997 XJ Cherokee
Really? Did not know that. You learn something new every day
post #8 of 9 Old 06-23-2013, 06:55 PM
biffgnar
biffgnar's Avatar
My mileage did vary. Worked fine in my TJ D44 and actually clutch packs lasted longer than I expected. LSD though poor substitute for real locker (no matter what some people try to convince themselves) so I don't miss it.
post #9 of 9 Old 06-23-2013, 07:10 PM Thread Starter
jbudz511
Well I don't have one, thanks for all your help!
jbudz511 is offline
