Changing from 242j to a 231 transfer case (Kinda emergancy) - JeepForum.com
post #1 of 23 Old 07-07-2010, 02:22 PM Thread Starter
locohosa
Here's the story, me and the girl friend split, and she agreed to go quietly if I gave up one of my vehicles (It was that or the home) and so I am gonna give up the Jeep. It needs a Transfer case though before it will roll away, so here I am asking questions. (I am keeping my damn bumper and off-road tires though)
The 242 is about $300 in Washington, and that's more than I had planned on spending. Since it just has to be drivable, and the 231 is half the price, what do I have to do to convert?
1990 Jeep Cherokee 4.0 auto
I just want her out of my life, with all the money I will have now, I will go get another project jeep for $500 in two weeks. Lol.
locohosa is offline
post #2 of 23 Old 07-07-2010, 05:09 PM
poorboy_616
1987 XJ Cherokee
Swap it in? I think the drivelines are all the same except for spline count. The shifter detents in the cab may be different, but just to get it rolling, leave it in 2HI and don't connect the linkage.....
poorboy_616 is offline
post #3 of 23 Old 07-07-2010, 09:19 PM
jeeptech01
I may be wrong but I think the rear ds lengths are different. Probably not different enough for a taillight warranty though LOL. Good luck!
SAK (swiss army knife) build - 01 XJ 3" lift, 4x4 conversion, HP30, Trussed 8.8 w/trac loc, 231j w/HD sye, Custom bumpers, on Treadwright 285 75 16 ( 380 horse 5.3 vortec 4l60e 242amg in the works )
jeeptech01 is offline
post #4 of 23 Old 07-07-2010, 09:47 PM
4jeepers
X2, Thats what I would do. 60 seconds or 60 feet, which ever comes first
4jeepers is offline
post #5 of 23 Old 07-07-2010, 11:26 PM Thread Starter
locohosa
-double post-
locohosa is offline
post #6 of 23 Old 07-07-2010, 11:27 PM Thread Starter
locohosa
So you are all rather sure that it will bolt up to the transmission, and the front Drive shaft, but not so sure about the rear drive-shaft length? That is perfect since I am putting a new drive shaft in her any way!
Will the linkage be able to function even if it looks less correct?
Thanks so much yall, the sooner I get this thing gone, the sooner I can ignore her.
locohosa is offline
post #7 of 23 Old 07-07-2010, 11:31 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
both driveshafts will work fine. the t-cases are nearly the same size.
1990JEEPXJ is offline
post #8 of 23 Old 07-07-2010, 11:36 PM
1990offroadYJ
i do know that the 90 cherokee has a 21 spline count for the input gear so at least make sure that the 231 has 2 spline. as for 4wd linkage i think its the same if not you just need to remove the bolt and turn the tab the linkage is on
1990offroadYJ is offline
post #9 of 23 Old 07-08-2010, 08:01 AM
jeeptech01
The gating in the shifter assy is different between the 231 and 242 and I thought the length of the lever was different to accomodate the longer stroke of the 242 range.
post #10 of 23 Old 07-08-2010, 08:37 AM
Holder350
1995 XJ Cherokee
I have swapped a 242 in place of a 231 and everything bolted back up just like it came out, driveshafts are the same and all the spline counts are the same AS LONG AS the xfer case being swapped in is from a 4.0
I left my old gate on the floorboard, and sold the jeep like it was.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #11 of 23 Old 07-08-2010, 09:02 AM
XJH-007
XJH-007's Avatar
This must have been like a 10yr girlfriend for her to think she gets the house or a RIG.
At any rate...the 231 will swap right in.
And an even bigger "emergancy" is learning how to spell emergEncy.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #12 of 23 Old 07-08-2010, 09:36 AM
99Greenmachine
so wait...she wanted a $2k jeep over a house? What is the house, a cardboard box behind walmart?
Make sure you try to get a similar year cause I know that the spline counts changed at some point
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #13 of 23 Old 07-08-2010, 11:06 AM Thread Starter
locohosa
its a $800 rig to be honest, and she wanted to keep the apartment, but since she has no job, no life, and no idea how to take care of her self, i said no. Its just easier that way.
Thanks yall!
locohosa is offline
post #14 of 23 Old 07-08-2010, 01:05 PM
keepishop
1989 XJ Cherokee
junkyard tcase maybe?
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #15 of 23 Old 07-08-2010, 03:31 PM
xj_mike
Sorry to say this but if you're not married, kick her to the curb. My divorce cost me $100,000 to get her to walk away but she owned half the house/cars.
XJ_Mike
2000 Cherokee Classic 4x4, Rusty's 2.5" coils with 3/4" spacers, OME 3" leafs, TnT Track Bar, JKS Lower Arm and Quicker Disco's, Bilstein's, 245/75-16 Dualer REVO's, AJ's Super Rock Rails, Warn Transfer Skid, Factory Front Skid, PORC SYE, swapped D35 for 8.25 with 4.10's and Trac-Loc, removed ABS system and more to come...
xj_mike is offline
transfer , case , swap , 242 , 231 , 242j , np231 , cherokee
changing Trans. and Transfer case. fluid? TwistedcaB- XJ Cherokee Technical Forum 17 11-26-2008 07:17 AM
I am changing TPS right now what kinda screw holds it in is it a hex or allen mtn121 XJ Cherokee Technical Forum 3 01-23-2008 08:31 PM
242J Transfer case swap out question RicksXJ XJ Cherokee Technical Forum 2 10-26-2006 12:38 PM
changing transfer case fluid ccockerham XJ Cherokee Technical Forum 12 07-01-2005 11:30 PM
242J transfer case Qs e043656 XJ Cherokee Technical Forum 7 12-11-2002 12:44 PM
