changed out trans, wont' start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > changed out trans, wont' start
THE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaSavvy Billet LED Tail LightsCurrie
Unread 09-21-2013, 10:35 AM   #1
myjeep179
1979 CJ7
2001 XJ with a 4.0L motor, I just replaced the transmission (automatic) with a 1998 automatic, everything went well, all connectors seem right. When I went to start it, it just turns over with no actual ignition. If you guys can give me some pointers I'd really appreciate it
Thanks
Bill
myjeep179 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2013, 11:00 AM   #2
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
Check the Crankshaft Position Sensor (CPS) and its wire harness. If you didn't remove the CPS during the install, even a small bump can damage the CPS.
Between 2009 when Obama took office, and 2013, median annual household incomes have fallen by more than $2,100.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
